Question about Whirlpool Dishwashers
My Whirlpool Gold Series 980 dishwater no longer fills up with enough water to drive the washing arms, so the dishes do not come out clean. I cleaned the filter on the water intake valve (which was really clogged) and it still did the same thing. Replaced the inlet valve and still no change. The water does not reach the level of the overfill float switch, so that’s not it. Its been working fine for 4-5 years, what else could it be? Thank you.
  • 1 more comment
  • cheeky13 Nov 19, 2008
    The problem still presists. I tested further by manually adding about 1 1/2 gallons of water after the automatic filling stopped and it seems to work just fine. Is there a timer switch that can be adjusted that will allow the basin to fill to a higher level?
  • cheeky13 Nov 22, 2008
    The water is getting in without a problem. The input valve has been replaced. Replacing the entire unit does not seem like the correct answer, as it works perfectly if I manually add about another gallon of water. What controls the fill level? Is it simply a timer that can be adjusted?
    So it turns out that there are two filters. I initially cleaned the one in front of the water intake valve. When I started pulling apart the plumbing lines, I found another filter screen that was also clogged between the copper pipe and the connector. Cleaned that out and it worked fine.
    To answer my other question, the water fill is simply a timed fill. There is no adjustment for that.
    Sergeant:
  • 276 Answers
I hve provided u with all details .read it carefully .it has all the resolutions for all possibilities
Posted on Nov 22, 2008
  • smarttech Nov 22, 2008
    some problem my data did not get loaded in my first reply. i will u give u the direct link to the sitefor all the details :
    http://www.applianceaid.com/
  • Whirlpool Master
  • 19,396 Answers
Test and eventually replace the water level switch, even if the water is not reaching the sensor, the switch connected to the sensor is probably defective and stop the flow on its own.
The water level switch is the device that stop filling, therefore that is the cause, even if its floating sensor is fine.
In sporadic occasions you can also have same problem caused by a faulty control assembly.
You find replacement parts here
    Sergeant:
    Champion:
  • 324 Answers
Check the pipe going from the valve to the hot water pipe under the sink.if it is a rubber hose it could be kinked or blocked. check the valve under your sink, if you had build up in the fill valve then you may have a blockage at you valve under the sink.
Posted on Nov 19, 2008
  • 73 Answers
Check the water pressure, check the hoses that connect to the washer allowing water to gain through, they may be clogged, check all valves and filters, or it just might be time to replace the washer, they dont last any longer tn 4 to 5 years, and if they do after that they tend to wear out. so its best to update every 5 years to avoid water leaks and so on.
  • 4,806 Answers
The reason for this is classic limescale build up clogging the jets and moving parts, get some limescale remover and add it to the washer cycle, you may have to repeat the process a couple of time to get rid of it all
best regards
Posted on Nov 17, 2008
    Scholar:
  • 181 Answers
 There are some good commercial products to clean water scale and calcium from the inside of your dishwasher...one is Rover , from Maytag.
For a dishwasher liner that is just looking "tired"....pouring in some crystal tang ( yes the drink )...run the dishwasher through a short cycle...the tang will freshen up the smell of your dishwasher and also help clean it out.
  • 1 more comment
  • fixyy Nov 17, 2008
    Do I really have to run the water in the sink before starting a cycle?
    Yes. Dishwashers work best with very hot water. Letting the water at the sink run for a few moments (until it's hot) before turning on the dishwasher brings hot water to the dishwasher faster.
    If there's no water entering your dishwasher, check these:
    Water-inlet valve
    Float switch
    Water-inlet valve
    The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
    Float switch
    The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
    he water doesn't drain from the machine
    If the water doesn't drain from your dishwasher, check these:
    Drain line/air gap
    Pump
    Drain valve and/or solenoid
    Belt
    Motor
    Timer
    Drain line/air gap
    A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
    Pump
    Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
    Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
    Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
    Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
    Belt
    One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
    Motor
    If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
    Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
    Timer
    Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Whirlpool gold dishwasher will turn on but not clean dishes
If it looks like the water is circulating then it's possible that soap build up can cause cleaning problems. Try taking a cereal bowl and filling it with an 8 oz bottle of apple cider vinegar (you want apple cider for the citric acid and you want to put in a bowl because the 1st thing a dishwasher does is drain) then put the bowl on the lower rack and wash nothing but the bowl of vinegar. We have found that the new non phosphate soap is also causing problems we have found that Finish tablets work very well and since they are pre-packaged then there is no risk of too much soap causing problems. If that doesn't help then it's possible that the motor is not turning the spray arm at a high enough speed to circulate the water. Hope this helps.
Jan 28, 2014 | Dishwashers
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
My dishes don't seem to be getting rinsed. They come out "gritty" and none of the food particles are being washed away.
Hi
Daniel
Mar 26, 2011 | Whirlpool KUDC03FVSS Builtin Dishwasher
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
The top rack of dishes are not getting clean. I
you need to check the upper wash arm for blockage from debris,if this is not the case,then you need to replace the water conduit from the lower sump area to the top arm,after time the water erodes the plastic conduit especially where it connects at the arms and water gets by these areas and can no longer build pressure to spin the wash arm
Apr 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The dishes don't come out clean after complete cycle or even after I re did the wash.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Oct 31, 2009 | Maytag MDB7100AWB Dishwasher
Dishes on top won't clean, seems to stem from arm below
Sounds like the water pump is not pumping the water. Or the most likely problem is that your arm is plugged with hard water or something. Take it out and clean it and check there first. Or something in the arm has broken and it no longer spins because it is not pressurizing correctly. Some acids will help disolve hard water and clean up the problem. I use a commercial grade acid for cleaning ice machines to eat away the hard water. Good luck and let me know if i can help you out anymore.
Sep 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
