Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error Code 5100
What does it mean? What is wrong with the printer?
  • 91 Answers
Thanks to Wayne Lischynski of Ebytes Computers, he posted this info on the internet. I hope it helps.
Binary Bob
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Wayne Lischynski - Ebytes Computers
Posted on Nov 17, 2008
SOURCE: canon pixma450 printer error code 5100
go crazy and hit it will work relly i tried it
Posted on Nov 20, 2007
SOURCE: error code
Error 5010
Posted on Apr 22, 2008
SOURCE: canon pixma mp530 problem error code 5100
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
  • 1555 Answers
SOURCE: What does the Error 5100 code on my printer mean?
If this does not work for your model revert back to me along with your model number
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Jul 24, 2009
  • 33 Answers
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Posted on Sep 13, 2009
Well, on a Canon printer, it means there is something wrong with the print cartrage.
May 29, 2016 | Canon PIXMA MP610 InkJet Printer
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Mg 2270 p2
Hi Andrey,
Did you mean P02?. If yes, means that carriage error occurs on your printer. This error is another format of error code 5100. It describes the same thing that applicable for all Canon inkjet printer model.
I hope the following link would be useful for you. Thanks.
Error Code 5100
Jan 14, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Pleace help me about code error 5100
The error code 5100 means that the ink cartridges can not detect by the printer.
Dec 24, 2010 | Canon PIXMA MX310 All-In-One Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5100
This might help:, they had the same problem
Oct 25, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error 5100
Don't quote me on this but I think any error code over E 200 means servicing required.
Sep 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP510 Error code 5100
Ink cartrige is in the wrong slot and now oth are stuck!!! what do i do????
Mar 31, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
