Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Heater surging i have a 75000 buddy pro heater less than 2yearsold only used 3 or 4 times. when i turn the power on it surges. flame goes on and off for about 20 seconds then it shuts off. HELP
  • 3 Answers
We are a service center for these type of heaters. The most common problem causing surging is the air pump and or the rubber hoses. If the pressure gauge holds steady then it is most likely one or both of the hoses. New from the box we get heaters with the hoses bent and sometimes even rotten. In an emergency you can turn the carbon vanes 180 degrees and put the pump back in service.
Posted on Dec 18, 2008
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
Carrier Weathermaker 8000 Furnace Flame Surges on start up
The fuel is controlled by the gas valve, the amount of gas is controlled by the regulator, I would verify that the inlet gas pressure is within the limits of the gas valve/regulator. The surging is likely the fault of the regulator and could be as simple as a spec of something in the orifice that allows gas pressure on the top of the gas regulator diaphragm. With the surge there must be an accompanied change in gas pressure at the gas valve outlet to the burners, use a "U" bend manometer to verify as they are the most simple and accurate and react instantly with no "averaging" software to wonder about.
Mar 16, 2017 | Carrier Heating & Cooling
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
Motor that turns the flame to the heat surge I would just like to order the part
If you're under the one year standard Warranty, since you purchased the heater, Heat Sure will replace it for you. If you're out of warranty contact Heat Surge 800-924-7964 and you can purchase the motor from them.
Apr 07, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
296 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
