WATER LEAK WHEN WASHING MACHINE GOES TO SPIN WATER POURS OUT OF DETERGENT DRAWER
  • hawki99 Nov 19, 2008
    Many thanks for the email, will give it a try
  • bscott359 Feb 02, 2009
    i also have a front loading energy star model WCXH208A1WW and after three years of regular use, water now FLOWS from the detergent tray approximately halfway through a regular cycle. GM denied any recall or problem.
  • Washing Mach... Master
  • 3,463 Answers
Probably slow to drain due to blockage or restriction, it is going into spin with more water in the drum than there should be.and the water is being thrown out due to centifrugal force.
If it has a filter, then check it and clean if required.
Posted on Nov 18, 2008
  • Barry Coates
    Barry Coates Nov 19, 2008
    If after cleaning filter it does the same thing, then possibly too much water is going into washer.
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
No detergent or water filling washing machine
Your outlet pipe may be fitted to low, it has to be raised above the level of water the machine will take in otherwise it will go straight out the drain pipe.
Dec 22, 2012 | Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Samsung washer is leaking water from under the front of the machine. not from the door. the drain pump works.
after it leaks, place machine on its side, look for wet spot, may be popped off hose or leak at pump, or rarely cracked drum if plastic.
Sep 02, 2009 | Samsung WF328AA Front Load Washer
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
