Question about Breville Die Cast 800ESXL Espresso Machine
Brand new machine is not working properly
I just purchased this machine, and have only used it twice. I had just finished making a perfect espresso, cleaned the machine and turned it off when my son said he would like a drink too. I plugged the machine back in and it immediately began pumping water into the drip tray, even before I turned the power on. I pressed the power button on and off again. Though the "power" button surround light seemed to be working properly, nothing changed. It continued to pump water from the water storage container to the drip tray whether the power was on or off. The only way to stop the water tank from being drained was to unplug the machine. I tried numerous times, with the exact same result. I removed the drip tray, the water tray and even the storage drawer and put everything back together as specified in the manual several different times. I even tried a different power outlet (I don't know, in case of a power surge or something?). Neither the "hot water" or "steam" buttons light up when pressed. Also, the machine was in the standby mode. I turned the dial from standby to steam mode and got only a steady stream of water from the steam wand (I assume this was because the "steam" setting could not be activated). I then turned the dial to espresso mode and got a steady flow of water from the brew head (with and without the filter holder attached). If anyone has had this problem, or heard it before, please help me. I'm afraid I got a lemon, even after reading so many great reviews prior to purchase.
  • 1 more comment
  • Brenda Stroyan Dec 01, 2006
    For anyone out there who is experiencing a problem with a Breville product, I must say I am very pleased with their service. After posting this message in frustration last night, I was able to call the customer service number on the back of the manual today. The conversation lasted approximately 15 seconds, with the representative stating that the machine was defective, that it should be returned and exchanged for a new one. I can't wait to get a new machine, since the two espressos I was able to make were excellent.
  • pearl32 Dec 11, 2007
    hi there,
    I too am having a similar problem with my breville espresso machine. Whereby i used to be able to froth the milk with no problems but these past couple of days, the steam button light is illuminated, when i turn the knob to steam the milk, the steam button's light goes off and the hot water gets illumintaed and all i get is hot water. It also does not make that thumping noise it usually does just before the steaming begins. Please help!
    I have tried clenaing it, letting the hot water run for a few minutes (not just seconds) but still the issue isn't resolved. I am thinking about taking it back to the manufacturer as it is still under warranty. Only prob is they are on the other side of the state :o(
    Many thanks,
    Alison
  • Anonymous Dec 16, 2007
    Same problem - I plug in the machine and it immediately starts emptying water into the tray, even before I push the power button. If I am able to brew a cup and try to use the steam feature, it just fills the cup with water - no steam. Such a beautiful machine - too bad it doesn't work!
    Frustrated!
5 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: My Breville800ESXL makes steam but does not make espresso.
jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Posted on Dec 02, 2008
  • 18 Answers
SOURCE: Not making steam
hi tried99X. couple of possibilities: have you made sure steam wand is completely clean? allowed adequate time for water to heat? try looking inside: unplug machine, remove the ten screws on the bottom and gently lift away base: it does have wires connecting it to rest of machine so be carefull not to yank on them. locate the hose leading from the pump to the steam-arm (may be hard to see; use a good penlight and a small telescoping mirror if you have to; Autozone & other auto parts stores sell them for a couple of bucks-if you don't want to take off the entire casing of the machine. does the hose look okay?) also see if the pump has vibrated out of position. also, when's the last time you descaled? good luck!
Posted on Jan 11, 2009
steve_s741
  • 3 Answers
SOURCE: bes820 when i connect power
It's a common problem with this family of machines, mine does the same thing from time to time. There is a potential solution posted on this site somewhere, you might find it by searching for Breville 800esxl instead. The same article also appears here if you can't find it, but the format is messed up.
The fix is complicated, and you'd need to be competent with electronics repair, as it involves replacing a faulty zener diode in the controlling circuit board. Also, I'm not sure if it's going to work for the 820, as when I pulled my 820 apart and looked at the circuit board it didn't resemble the one shown in the article. There is a pretty good chance that they share a common component in this zener diode though, judging by the behaviour, so this circuit diagram will help if you want to have a go at fixing it. Replacing the entire control board would probably be achievable if you don't have the skills to replace the diode.
Also, dismantling the 820 will be a different process, which you can find in my other post here.
Personally, I just put up with the problem and turn it off at the wall if it won't *******.
Posted on Apr 09, 2011
  • 910 Answers
SOURCE: Hi, when the machine indicates
One or more of the seals have failed on the boiler unit (Item 251 at link below) and these are no longer available as a replacement part.
Depending on your technical ability you could look at opening the unit and checking for any visible leaks or faulty seals that you may be able to replace with an equivalent part.
http://www.ereplacementparts.com/breville-800esxl-diecast-espresso-machine-parts-c-116052_116055_116066.html
Posted on Jun 20, 2011
Just got brand new machine and won't make water or steam (yes, water tank full and properly attached)
then dump the water and return it to place of purchase with receipt as defective .
Mar 26, 2016 | Coffee Makers & Espresso Machines
My steamer is not working properly
Take the nozzle off and wash well also there is a small hole pin size at the top clean out with a pin and push the black inside piece inside nozzle out 2/3 MM out it must pop out I use a chop stick it's perfect. I had the same problem perfect now
Nov 07, 2015 | Gaggia Titanium Espresso Machine
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
Aug 30, 2015 | DeLonghi Magnifica Coffee Makers &...
I have just purchased an ISOMAC TEA and I have followed the instrution however it now wont fill up and start to boil even though I have pulled the lever out and allowed the water to flow
Some times brand new machine if they stay for months not in use then the volumetric water pressure pump is stuck. And you should remove it from the motor rotate it manualy ven use a litle lubricunt oil and put it back again then the pump can work perfect for many years.
Feb 09, 2010 | Isomac Tea Espresso Machine
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Dec 29, 2009 | Saeco VIA Venezia
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Dec 24, 2008 | Nespresso Aeroccino Automatic Milk Frother
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group: http://cerinicoffee.com/Saeco_brew_group_Magic_royal_916006715.asp
Cleaning instructions: http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Problems with Saeco 762111651808 Espresso Machine
If the machine is digital you will go into the menu and reset the option that says signal descale. The machine does not know if you descaled it or not, you will have to tell it.
If it is not digital, hold the steam or descaler button(depends on model) down until the light goes off.
Hope this helps!
Sep 23, 2007 | Saeco 762111651808 Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
62 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
superdad1976
Gene Pitts
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
