Question about Dishwashers
GE Dishwasher Speed Cycle Should be 35 minutes but is 50 minutes
GE Dishwasher Model GLD6300L . The Speed Cycle should be running for 35 minutes and instead runs for 50 minutes. Is there a way to reset this or do I need a repairman? The dishwasher was purchased from Home Depot in in Dec. 2006.
    Sergeant:
    Champion:
  • 251 Answers
U might want to try a dishwasher cleaner the contact a repair man u can use our directory to locate on in ur area
Here to help
Shaun
Posted on Nov 17, 2008
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
Jun 23, 2014 | GE Dishwashers
Bosch dishwasher actual runtime versus indicated runtime.
The usual discrepancies with run times is due to water heating time.
For example, your dishwasher may be estimating run time + time to heat the water from cold.
If your dishwasher is connected to hot water instead of cold, it will skip the majority of the heat cycle and adjust the time accordingly.
On the other hand for other people, their dishwasher brands may say "50 minute wash" but this does not take into account heating time, so wash can be anything up to around 70-80 minutes.
Jun 01, 2013 | Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
I have a GE PDW8400JO3BB dishwasher.It use to take 53 minutes to do a normat load and now takes 83 minutes. Why
There could be a few reasons for this..
Most likely the water temperature is not reaching the optimum temperature required for cycle.
The incoming water supply pressure could be lower which means it takes longer to fill.
The turbidity sensor might not be functioning properly causing the dishwasher to prolong the wash cycle.
Best to run the dishwasher empty with a Finish dishwasher cleaning kit that you can purchase from the supermarket. The instructions are written on the kit.
this should help clean dirt from all the sensors that are located in the tub.
Hope this helps.
May 16, 2011 | GE Dishwashers
Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
Sep 15, 2010 | 1998 Mitsubishi Eclipse
Will not pump out all the water, I hear it click, but I don't hear the 'whirr' just a 'hmmmm'. is there a solenoid gone bad, or the pump motor?
Pumpkin seeds blocked the drain line, so $180 to the lucky plumber as he drove off in his Mercedes back to the country club!
Nov 09, 2009 | GE 24 in. GLD6300L Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwashers Logo
197 people viewed this question
Top Dishwashers Experts
