Question about Sony STR-DA3000ES Receiver
When I power on my Sony STR-DA3000ES is gives an error code that first says "STREAM" with "(unlock)" below it, then goes on to display a flashing message "PROTECTOR" with solid "check code 22" below it, then turns off.  What does that mean? How do I fix it?
  • learnapplypr Mar 31, 2009
    there are not yet speaker cables connected.  It happens when the unit plugs in and powers on without any connections to it yet.
  • 757 Answers
Incorrectly connected speaker cables is a common problem that is easy to do, but easy to fix. Check your connections.
Posted on Mar 30, 2009
  • Mike LaPres
    Mike LaPres Mar 31, 2009
    If it does this without ANY connections to it at all then a short can't be to blame. At this point, I'm doubting the next step will work but it's worth a shot before sending it back to where it came from for repair.
    Plug it into the outlet, and when you press the power button hold it in until the unit "clicks." It might take upwards of 15 seconds to do so. Then try again to power it on.
    If the problems still exists then it sounds like the amplifier section may be damaged.
    May I ask about when exactly was the first time it did this, what was connected?
Error code 11 protector unit has no speakers
My only suggestion on the above information would be to reset the receiver. You can do this by first turning off the receiver. Once the receiver is off, hold the Power On button down for 5 - 10 seconds. This will reset everything to the factory settings.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Error code how do I reset
Turn the receiver off. Once off, you hold down the Power On button down for 5 - 10 seconds. This will reset everything to the factory settings.
How do I reset the system
My str3000es when turn on the screen show STREAM UNLOCK and PROTECTOR THEN turn off by itself
Check all of your speaker connections at both ends for looseness or any stray wire strands. If they make contact with the chassis, this can and often does cause the electrical short that is making the receiver go in to protect mode. The protect mode prevents electrical damage to the amplifier.
Once you have all of the above verified and fixed, try to power it on again.
Dec 04, 2010 | Sony STR-DA3000ES Receiver
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
The DC detection circuit is triggered when the speakers are connected.
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
There is a defect in the final amplification stage of the receiver. This may have been caused by a short in the speaker wires. The typical defective parts are the output transistors. Expect a parts cost in the $40 range for this repair. Any audio service shop should be able to repair this.
Sep 21, 2009 | Sony Audio Players & Recorders
Sony str-da3000es
This appears to be an error message that is given due to copy protection on blue discs....
Dec 17, 2008 | Sony STR-DA3000ES Receiver
Fix my receiver
irregular current is output from the speakers...turn off the receiver, check the speaker connections and turn on the power again.
Jun 28, 2008 | Sony STR-DA3000ES Receiver
Open Questions:
Sony STR-DA3000ES Receiver Logo
701 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
