Question about Welding Tools
Millermatic 200 will not weld
I have a millermatic 200 that will not weld. It dosent seem to have enough power to the tip.The power supply is good. The wire feed is good.
In put power supply jumper not set to right voltage
Posted on Jan 09, 2009
  • 169 Answers
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Posted on Nov 29, 2008
HOw do i fix a help 7 code on my millermatic 350p welder
If you have three phase or 110 v supply it will not work.
May 04, 2018 | Welding Tools
Millermatic 200 fan won't quit running I live in Casa Grande Arizona and it's really hot do you think that might be the problem
Call a electrician unplug it turn off the breaker turn off the switch www.apparelstore38.com
Jul 14, 2017 | Miller Welding Tools
Ak matic 1200 welder
Akmatic 12000 is a Millermatic 200
Akmatic 1250 is a Millermatic 250
May 24, 2014 | Miller Welding Tools
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Millermatic 130, fan motor coil burned out, where can I find replacement part
The part number you are looking for is MIL 111931 MOTOR FAN. Order it with your local welding supply store. I will recommend Praxair.
Feb 01, 2011 | Miller Welding Tools
Have a miller Millermatic 130XP drive roll not working
Have a 130 xp welds the same with or with out the gas welds not smooth
Jun 29, 2010 | Miller Welding Tools
Millermatic 200 won't weld
first check on the plate that tells imfo of unit ,there is what is called duty cycle.If the duty cycle says per say 30%,that means you can weld full power for 3 minuets before unit will shut down to cool.if it says 100% duty cycle there is no limit on weld time.this is the first thing to understand,if that is not the case check the main contactor where the power imput wires go,pull the gun trigger see if the contactor is pulling in , it should if not no welding amperage.
Jul 11, 2009 | Miller Welding Tools
Open circuit??
try blowing out the welder
Mar 19, 2009 | Miller Welding Tools
Welding Tools Logo
1,150 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
