Startup problem ibm thinkpad t43
My notebook is having issues starting up. Whenever i turn it on, it barely gets past the bios messages and then turns itself off. I have tried;
- removing the battery and starting it up with the power connected
- removing the hard drive and booting with a live disk
- booting to bios
but none of these things work. It goes off after a few seconds.
Any ideas on how to fix it are welcome. Thanks!
  • 4,806 Answers
This could be one of a few things: 1 overheating, get a can of compressed air and blast the air vents and the fan, there could be a build up of dust and fluff causing the machine to overheat.
2 corrupt bios, this is a nightmare to techs like us!! mainly because its a last resort when all other avenues have been exausted and the bios has to be flashed, if you can locate the motherboard battery and take it out for 10 mins, this will clear the cmos, you will have to open the machine up to do this.
3 the CPU fan has stopped working, turn the machine on and listen and look if you can to see if the fan kicks in
If all these fail check the seating of the CPU heatsink to make sure that it fits nice and snug
Posted on Nov 16, 2008
    Sergeant:
  • 237 Answers
Are there any status lights on? What are the circumstances that led to this issue? and Lastly, describe the climate you use the laptop and how long you use it during any normal period of time?
I ask these questions because I have a clue to what your problem is.
IBM Thinkpad t43p super password
Kindly inform us which type of password (BIOS password or Windows login password) are you talking about? It's not clear in this message.
Oct 16, 2012 | IBM ThinkPad T43 Notebook
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
I have a T40 IBM that just got the 1802 error. downloaded a bootable fix that I made to a CD. Set both startup and network to look for the CD drive first. Cannot get past the double beep on the POST test...
To correct this issue, you will need to remove the PCI wireless card from your laptop or disable the mini PCI settings in the BIOS menu.
On IBM's, the Mini PCI card slot is usually at the back of computer.
After removing card or disabling the
mini PCI settings in the BIOS menu, boot your computer. Make sure to update your BIOS. The new BIOS version can be downloaded from the manufacturer's website.
(http://www-307.ibm.com/pc/support/site.wss/MIGR-51708.html).
This issue has been corrected in the latests BIOS updates released.
After updating the BIOS, you can reseat the PCI Wireless card or enable the mini PCI settings in the BIOS menu.
Note that once you have removed the wireless card, you will not have wireless connection until you update the bios and replace it.
Hope this helps.
May 19, 2011 | IBM ThinkPad R40 2722 Notebook
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    T43 upgrading bios
    The bios needs an operating system to work. That's why it's called an operating system. DOS will even work but, you must have something.
    Jul 31, 2009 | IBM ThinkPad T43 Notebook
    T43 speaker not work, use ear phone is ok, any
    go into your laptop's Bios and check that the speaker are not muted in the Bios
    Jun 24, 2009 | IBM ThinkPad T43 Notebook
    Ibm thinkpad t43 backlight inverter issue
    Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
    Jun 13, 2009 | IBM ThinkPad T43 Notebook
    BIOS self-set Password after upgrade/HD Install
    http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
    try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
    May 28, 2009 | IBM ThinkPad T43 Notebook
    Ibm thinkpad laptop plugged in powers off after about 15 minutes
    Have you checked the power settings in the BIOS set up? There are ways to automatically turn off machine there.
    Dec 10, 2008 | IBM ThinkPad T43 Notebook
    Computers & Internet Logo
    408 people viewed this question
    David Payne
    David Payne
