Question about Sharp AL-1551 Laser Printer
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
My printer/scanner worked fine, but we had a power outage (it's plugged into a surge protector) and now it won't work. It keeps flashing the number "4" and then the letter "H." I understand there's a series of buttons to hit to reset it, but I don't know what they are for my particular model. Any help would be greatly appreciated!!!!
Thank you!
Sandy
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Posted on Dec 03, 2008
Error message L3 is flashing
scanner sensor not working,so scanner return trouble.clean it than fix problem
Mar 26, 2014 | Sharp AL-1451 Laser Printer
My Sharp 1551CS has a "4" and "H" flashing in the quantity indicator. Copier appears frozen.......HELP!!!
To reset the H4 condition on Sharp AL series copiers press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service. Good Luck and Thank You for using Fixya. WheatlandServices
Nov 29, 2010 | Sharp AL-1551CS Printer
My Sharp AL-1551CS copier is flashing L 3. What
Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Good Luck and thank you for using Fixya.
Mar 15, 2010 | Sharp AL-1551CS Copier
Sharp al-1655cs where is the scanner head locking switch?
On my Sharp AL-1551CS, it is located on the left end underneath the scanner unit.....it is a knob that rotates only 1/4 turn to either lock or unlock.
Feb 26, 2010 | Sharp SHP AL1655CS Printer, Scanner,...
I have a Sharp AL-1551CS that when turned on shows an error message and will not work. The error code referenced in the maunual says to remove the shipping screw. I have had this unit several years. what...
instead of a screw, some models have a dial to lock the scanner for moving machine. look above where the paper exits machine twords the left side under the scanner assembly for a dial switch and turn it.
Nov 11, 2009 | Sharp AL-1551CS Copier
Sharp AL 1551cs reading L
I also have an AL-1551CS copier...normally the "L" has something to do with the scanner lock device underneath the left side of the top part (ie; the scanner) It's clear colored and round with protrusion to turn it from locked to unlocked...this is for moving the copier so the scanner (lamp and mirror assm) won't be disturbed. Use a flashlight or such to inspect the position of said device (ie; locked or unlocked) insure it is unlocked.....power back on and tell me if there is a number following the "L" Tim
Jul 03, 2009 | Sharp Office Equipment & Supplies
My al-1551cs sharp printer displays L1 and nothing works
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Jun 09, 2009 | Sharp AL-1551CS Printer
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Sharp's Vista Driver does not install
I had to add a printer manually after going through the driver installation process. Add printer,next,local printer (do not check plug and play),next,create new tcp/ip port, next, type in the printer ip address, next, I used the Generic network card here and it worked fine for me. You can figure it out from here
- Oli
Nov 25, 2008 | Sharp AL-1551CS Printer
H 4 error
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Sharp AL-1551 Laser Printer Logo
204 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
