Question about Panasonic TH-42XVS30U 42 in. Plasma HDTV
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
It seems the remote sensor on the TV has somehow partially failed. I have the Direct TV remote as well as the remote that came with the TV. Both have new batteries and the Direct TV remote works fine with the Direct TV DVR/Satallite box. However, when I go to increase/decrease volume, it stopped working for no reason. I thought it might be the remote itself so I used the actual Panasonic Remote and none of the functions from the remote to the TV worked. Just for kicks, I walked up to the TV and put the remote about 10 inches from the remote sensor on the TV and it worked. The same was true using the Direct TV remote. So my conclusion is the remote sensor on the TV has lost it's ability to sense the remote signal from more than 10 inches away. I turned the TV off and even unplugged it trying to "RESET" everything. It didn't work. Do you have any suggestions?
  • 318 Answers
Take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Posted on Mar 26, 2009
Reprogram A DYNEX ZRC-102 Remote Control
If your Dynex remote can't control your Dynex TV, you need to try replacing batteries and testing operation. If no success, the remote or the sensor in the TV may have failed.
Aug 16, 2016 | Dynex Televison & Video
LG 32" TV remote function fails to work intermittently. Works by using buttons on side. LG's remote for sound and DirecTV's remote for turning on station tuning. Batteries new in both remotes.
Try looking for the remote sensor. It should look a little like a camera lens or little red tinted window. If you cannot find it just give the entire front of the TV a good cleaning. Finger prints and dust build up can interfere with the signals. Do the same for your direct TV box.
Jun 02, 2015 | LG 32LC7D Television
Olivea tv rc-lte remote
Do you mean that the source button on the TV itself does not switch to the input of the TV that you are connected to?
Apr 22, 2013 | Olevia LT32HVM 32 in. LCD Television
My Sansui HDPDP4200 42 inch Plasma stopped powering up. When I hit the power button (both on the TV or by the remote) the green light comes on for about 2 seconds then shuts off. I tried to turn it back on...
Plasma TV's are notorious for power supply problems, its most likely failing capacitors in the power supply. If you can find a repair shop i would take it in, otherwise you might also be able to find a replacement power supply board online, but its a crapshoot to find a good one so its better to try and repair/rebuild the one you have. If all else fails its just time for a new TV. It sucks, i know, but i see so many 2-3 year old TV's failing its like a plague of the repair shop.
Jan 01, 2018 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
I tried 6 remote codes to consllidate my Direct TV remote with my Mintek DTV-265-D. Nothing works.
None of them will because this tv is newer than the remote : when the remote was being designed and its codes stored the tv was not designed yet so its codes could not have been added to the remote's collection.
All you are left to do is to perform a code scan, maybe one of the codes destined for another brand of tv will partially match yours and give you basic control. If even that fails there is nothing else to do - this remote doesn't have any codes matching your tv. You will have to buy and use another universal remote if you still want to use a single remote for both devices.
Sep 13, 2011 | Mintek DTV-263 26 in. LCD Television
Cannot find code to work Emerson LCD TV with my direct TV remote, does one exist?
Unfortunately no, your model of tv isn't supported directly. But you should do a full scan on the remote, one of the other codes might work, even if only partially.
Jul 01, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Purchased new sharp aquos lcd and when the tv is facing forward the direct tv remote will not work. With tv facing side remote works fine. Seems the picture is interfering with the remote. Direct TV says...
more likely the remote sensor is misaligned in the tv, and it needs to be pulled out straightened and replaced back in , maybe even the receiver board will need to be replaced. they are small in size and if the tv is in warranty then it will be easy to get it replaced.
the picture does not interfere with rf or ir signals the image is passive. to check the remote you could simply tel direct that the remote stopped working (no matter what tel the phone person it doesnt work...
that will get you a new remote and then you will know if it is the tv or the remote.
Jan 31, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Panasonic TH-42XVS30U 42 in. Plasma HDTV Logo
448 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
