Question about Frigidaire Dishwashers
The top part doesnt spin anymore and dishes come out unclean. The sound of the washer apperas to be the same but when i open the washer midcycle it doesnt seam to spit out the water with any power? What can i do to check this? What maybe wrong Horacio
    President:
  • Frigidaire Master
  • 2,651 Answers
Clean the lower filters you may have clogged them or check for proper water supply to unit, not enough water will have hte same effect
Posted on Nov 17, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
The washing machine doesnt spin or work anymore as normally
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 07, 2009 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Whirlpool Ultimate Care II washer will not spin...
I would say you have a burnt out clutch. did you over load it with a quilt or comforter?
Time to consider a new washing machine, unless its under warranty I would recommend replacing the washer vs. fixing it.
Whirlpool doesnt build them like they use to!
Jul 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series top load washer - no spin
the older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Mar 19, 2008 | Washing Machines
Top blade not turning
does it turn freely??
like if you give it a swind does it take about 6 revolutions then slows and stops?
if it does unscrew it (silver screw) and check the holes and washers and screws etc... as they can break perish.. if you dont know what to look for here i a tip!!
go snooping at any respectable white goods store, find the same model that you have and pretend to examin it lol! look at its top arm and see if it mooves as freely as yours!!!!!!
and for same parts etc.. anyhow the point is that if it moves freely then when the pump goes on the water should force it to spin smoothly!
however. get your self some dishwasher cleaner!
for the dishwasher! not the dishes! it is like a drain-o for dishes! it unclogs and un clags the pipes etc...
good luck!
Oct 13, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
94 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
