Question about Microwave Ovens
Kitchenaid Built-in Microwave Oven LED light in Control Panel
Our Kitchenaid Built-in Microwave Oven Model KBMS1454R has lost the bottom line of the LED light. The clock time is missing the lighted bottom line making it hard to read the time.
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
  • 96 Answers
SOURCE: Replacing the lamp in the microwave of a Kitchenaid KEMC378KSS01
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
I hope this help
What About Bob
Posted on Feb 11, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
I have a kitchenaid built in microwave oven, the light is out and I can not figure out how to replace it. The light is in the center of the roof panel and there is no way to get to it from the inside of...
http://www.kitchenaid.com/ then service and support. Suggest you start there since you didn't mention model number or anything else i could use to run it down.
Nov 04, 2013 | KitchenAid Microwave Ovens
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The 5 "buttons" on the right side of the control
The button pad is usually connected to the control board with a ribbon connector. They can become slightly loose, with vibration, over time. If you open the unit up, you will see where it is...it will be near the control panel. Detatch it and reconnect it. If it's a different system connecting the panel to the board, check any wire connections (disconnect and reconnect, ensuring they're tight), or solder joints for cracks, or cold solder joints (coudy looking joints, not shiny).
It could be a bad component, but since it's recurring, it's either an underengineered control panel, or a bad connection of some type.
Inspect it carefully, reconnecting any loose connections.
Good luck, and hope this helps.
Feb 25, 2011 | KitchenAid KBMS1454R Microwave Oven
Clock/timer light elements are burning out in my kitchenaid microwave model KBMS 1454R. I need the procedure for replacing the clock/timer display.
should come in the package with replacement parts. With whom do you deal? Is there a Johnstone Supply near you?
I have found a great resource on the WWW for otherwise obscure answers at RepairClinic.com. They have the parts you require and they have a answer guy there that is as good as a auto parts counter guy.
I hope you have found some value in these comments.
a
Sep 23, 2009 | KitchenAid KBMS1454R Microwave Oven
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
pupista@gmail.com
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
KitchenAid KBMS1454R 1000 Watts Microwave Oven
Sounds like the keypad is okay, unless it might be intermittent.
Your wall voltage is within the proper range.
It sounds like it might be bad connections on the control board causing functional and display problems.
I work on control panels, actually, but I can't find any service data (yet?) on this model.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Did you find it?
Any chance you could scan and e-mail it to me?
Please feel free to contact me directly.
prototech@usa.net
http://www.microwavedisplay.com
Jul 04, 2008 | Microwave Ovens
Kbms1454r
Your magnetron is leaking and needs to be replaced.
Oct 29, 2007 | KitchenAid KBMS1454R Microwave Oven
Microwave Ovens Logo
203 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
