Question about Admiral AW22 Top Load Washer
Water fills to overflowing without stop
This is for an Admiral mod. # AAV7000AWW. The water doesn't know when to stop. I opened up entire top and found that mice had chewed through a thin clear rubber hose. One end of the hose is attached to the outer side of the wash tank. Goes for about 16 inches to where the mice chewed through it. Can't figure out where this hose was supposed to attach to, and how long it should be. Can't find a hose diagram for this model anywhere.
  • Jim Blaine Nov 27, 2008
    Good job! Thank you !
    Genius:
  • 1,028 Answers
Replace the hose ..connects to tank other end goes under console to water level switch so no level control
Posted on Nov 17, 2008
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
Admiral aav7000aww water slowly leaks into tub when machine is off
You need to replace the water valve. here is a link to the part. Here is a video to show you how to replace it.
Nov 28, 2010 | Admiral AW22 Top Load Washer
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Water overflowing from Wasing Machine AAV7000AWW Admiral
this is 1 of 2 problems. either the pressure switch is no good or the pressure switch hose has a hole in it causing the air pressure from triggering the switch. locate the pressure switch and pull the hose off the end. start the washer and try to blow into the end where the hose was connected. if the water stops then you will need to replace the pressure switch hose. if the water doesn't stop coming in then you will need to replace the pressure switch
Jan 01, 2009 | Admiral AAV7000A
Admiral Top loader leaking water
water inlet vale has internal malfunction
Jul 20, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
145 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
