Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry camera My camera application on my blackberry is not working. it says: "could not start the camera. Close other applications and try opening the camra again." i closed all apps., i wiped my data, i did a battery pull, i restarted the whole phone, ive done everything, i even went to the store but they just tried to make me buy a new memory card and thats not the problem bcuz i deleted all my pictures just to try and fix this stupid thing.
  • 5 more comments
  • bcarrel Nov 30, 2008
    I have the exact problem. I even had an new camera put in and it still doesn't work.
  • Anonymous Jan 04, 2009
    the same problem close another aplications and trie again latter
  • Anonymous Feb 18, 2009
    I have the same problem. I try to start the camera when no other apps are open and it gives me the same pop-up.
  • annsaw1174 Feb 25, 2009
    i am having the same problem and i also tried a hard reset..after that problem is still there
  • bradyhill27 Mar 01, 2009
    I have the same problem and that guys solution doesn't work
  • Anonymous Mar 04, 2009
    Shut it down, pulled both the Micro SD card and the battery and let it sit for over 2 minutes. Still have the camera issue. I just recently upgraded the AT&T software to the 8300 5.4. Going to try and down grade it back to the 2.4 and see if it works or not.
  • Anonymous Apr 07, 2009
    what to do ????
Turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Posted on Feb 12, 2009
Could not start the camera close other applications and try opening the camera again blackberry
could not start the camera close other applications and try opening the camera again blackberry
Dec 07, 2010 | RIM BlackBerry Pearl Smartphone
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry storm camera quit working. it says could not start the camera. close other applications and try opening the camera again. i dont have anything else open
if you hold down the blackberry button....(dots).....a menu will pop up ....those are all the apps the you still have open...go into all of them and make sure you manually close them out....choosing the close selection on the menu....and ur camera should come right back on...the same happened to me......
Dec 25, 2009 | RIM BlackBerry Storm 9530 Smartphone
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Could not start the camera. Close other applications and try opening the camera again
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
AT&T Blackberry Curve 8300 Smartphone Logo
445 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
