Samsung HL-S5688W. Lamp blew up last February. I left the tv alone until Nov. 4, when I replaced the tube and turned it on to watch the election results. Have been watching it since then, and the sound only comes out of one speaker and is not so loud, even when I turn up the volume a lot (like in th 70-85 range). I checked the balance and it was OK. Any ideas? Thanks! Kevin in PA
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
One or both of your audio amps is damaged and in need of repair. OR you could connect the audio outputs to your audio receiver and use set that way. That is what I have done. sounds much better also!
Posted on Aug 29, 2017
tvguy171
  • 106 Answers
SOURCE: Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Posted on Dec 16, 2008
SOURCE: Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Posted on Mar 13, 2009
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
SAMUEL011
  • 39 Answers
SOURCE: my samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Posted on Jan 07, 2010
We have a Samsung HL-T6176S DLP TV I currently have no picture. When I plug the TV in after a few minutes all 3 little lights in the lower left corner of the TV flash on and off, and still no...
The "LAMP" LED light indication flashes or stay on?The tv projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Oct 22, 2010 | Samsung HLT6187SAX 61" DLP HDTV
TV comes on with a good clear picture and about 30 to 40 sec goes off.
The tv projection lamp have not been replaced in this tv like the last 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours a day?Yes,than the tv projection lamp life is over.The tv projection lamp,require replacing.
Oct 18, 2010 | Samsung HL-S5087W DLP TV
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
50''dlp had to replace the lamp, picture not as good as before
ok what you should do is to check in the old lamp the part number and who made it. dont believe what some sellers try to envolve, if you dont have that info check with tv model what part really is missing.......saludos
Nov 17, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
My tv turns off
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Bightness Change
It sounds like your lamp is going bad. The lamp part number is listed as "lamp code" on a sticker located on the left side of the set. Use this number to grab a replacement off ebay.
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
