Question about Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan
Remote not working at all
Cant get remote to operate at ALL...Fan remains on low will not increases speeds & has to be turned off at wall switch Remote doesnt operate light at all....Ive changed batteries and bulbs. Can I use fan & light by changes out of fixture without remote???
please advise ASAP
  • Laguna63 Jan 24, 2009
    I have a similar situation. I don't recall the model but its silver with 4 lights with 4 black fans. I cannot find the manual for this fan where it can tell me where the fan's code switch is located. Does anyone know? I tried replacing the remote with a replacement remote but that did not work. So, I have to assume I now have 2 remotes that work and a ceiling fan that does not. This fan has been working for years when it stopped working a few months ago. I never changed the code switches so its by default on 1 "up" and 2,3,4 "down". thanks.
  • Shaun Plencner
    Shaun Plencner May 11, 2010
    is the wire to the remote hooked in to ur power switch did it work before
    Sergeant:
  • 227 Answers
Check the fan and the remote to see the code switches are same. Sometimes depending on the age and humidity you may have to slide the switches back and forth to clean the contacts. Did it ever work? Are the batteries in the proper polarities? The fan and remote have to have the same numbers picked to operate properly.
Posted on Jan 11, 2009
  • carmen721t
    carmen721t Apr 20, 2013
    Where can we find the switches in the fan?
  • carmen721t
    Where do we find the numbers inside the fan to make sure they match with the remote?
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan Logo
227 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
