Question about Panasonic DMR-EH55 DVD Recorder/HDD Recorder
Cannot hook up my DMR-EH55 unit with new digital cable box
I want to hook it up in conjunction with new digital cable box, amplifier and digital TV so I can record TV programs.
The drawings in my manual are not exactly what I need. Are there drawings online that I can view?
Jim Gibson
Oklahoma City, OK
    Problem Solver:
  • 14 Answers
You can always make use of the LINE IN inputs.
Posted on Dec 04, 2008
My Panasonic DMR-EH55 has suddenly stopped outputting. Regardless of whether I am using the HDMI or component outputs, my Sony tv indicates "no signal". What kind of problem am I looking at?
Try it with another TV, perhaps a friend's or neighbour's. If the problem persists, consult your local Pana service centre or a competent technician
Sep 25, 2013 | Panasonic DMR-EH55 DVD Recorder/HDD...
We have a Panasonic DMR-EH55 dvd recorder, it worked just fine until March, 2009 when Shaw quit subscribing to tv guide. Has there been any resolution to this issue?
Shaw like Time Warner in many areas of the U.S. will never go back to TV guide.
Your best bet is to switch to the competition in your area.
Jan 31, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The...
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
Nov 02, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH55 Ram Drive Problem
Do you mean you want to replace the hard drive in the unit? If so, I have one of these units and I installed a new PATA hard drive and then "prepared" it with a firmware update that is available from Panasonic's website. I tried to increase the capacity by installing a 500GB hard drive, and also a 300GB hard drive, but no matter what size I put in, after I initialized the new hard drive with the firmware disc I always only had 92 hours available to me. In fact there was never anything wrong with my unit, I was only trying to increase the capacity for recording - which I was never able to do. I did find that another 200GB hard drive I tried didn't actually work for some unknown reason, but the 500GB, the original 200GB and a 300GB hard drive worked no problem every time I swapped them around. Let me know if you need the link to Panasonic's download - it's easy to find.
Jan 23, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH55 Ram Drive Failure
Buy a used DMR-ES15, DMR-ES25, DMR-ES45, or DMR-ES46 with a good DVD drive and swap out your bad drive.
Panasonic recorder
Have you checked your cables? Start resetting one unit at a time until you isolate the culprit. Don't forget the simple unplug all units to let them reset. .
Panasonic DMR-EH55
Motorola 6416 DVR
Sony STR-DA5000
27 analog tv!
Sony 5 Disk DVD Changer
5 speakers
PC connected
You think I have fun when something hiccups? A software snaffu? Bad a/v cable? Loose speaker wire? By the way-my online support is getting better and better. Charter cable has live chat, as does Sony and Motorola. Good luck. Also, I can't think of a single setting I've changed with the Panny. other than assigning digital audio out settings. DEcoder setting? Your Panny?
817-230-4017 if you haven't fixed it.
Dec 09, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
MY DMR-EH55 has problems repsonding to the supplied remote control
Firstly, check you do not have bright light shining across the IR sensor.This can degrade the signal to noise ratio of the IR receiver.
Second, check you do not have a noisy mains electricity supply, arcing plug block or running from square wave inverter supply. Either of these can cause problems with IR receiver in the DVD player.
Feb 25, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH55 DVD Recorder/HDD Recorder Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
