Question about POSX POS-X (XI1160KB) Handheld
Not reading barcodes
On our barcode scanner (pos-x 1160) it is not reading barcodes, just beeps three times and has a green light. Restored to default settings and still same problem. Please help.
SOURCE: Installation of Xi3000 Barcode Scanner
Depending on what you need to do, you may or may not need the ScanManager Software. If you simply want to append a TAB rather than a Carriage Return, or disable the 0 in front of UPC-A barcodes, this can easily be accomplished using the manual.
It is only with rather complex operations (say, omitting the account number on fedex barcodes, resulting in a scan that only returns the tracking number), then you will probably need the software.
If you have any questions, let me know.
Posted on Oct 12, 2007
0 characters
1 Points
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one?
This one below is for the HHP 3800r ?
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Jan 22, 2008 | Symbol LS 4278 Barcode Scanner
POSX POS-X (XI1160KB) Handheld Logo
Top POSX Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you a POSX Barcode Scanner Expert? Answer questions, earn points and help others
