Question about Cuisinart DLC-8S Pro Custom Food Processor
Can't find white clip to DLC 8
I have a DLC 8. I've misplaced the small white clip that slips under the lip cover in back. When you snap the bowl to the base and then snap the cover in place this clip slides over the white stem in back that allows the power swicth to activate. I have everything but that! I've called cuisinart and they didn't seem to know what I was talking about. My unit was purchased in the late 80"s but still works like a dream. I did find an entire unit on ebay and the seller sent me a photo.
  • 1 more comment
  • Anonymous Nov 17, 2008
    I have a Cuisinart Custom 11. The white clip broke years ago, but I could manually stick it in when turning the cover and it too worked like a dream. I cannot find it now and withhout my processor. I have all my accessories plus the DCL-8/DC:10 box of additional discs which work with my unit. I would just like to replace the clip, or fanagle it somehow to work.
  • elainesollar Nov 28, 2008
    Thanks Mhughes but no repair shop here.
    My clip is MISSSING not broken. I need to find a replacement part.
    Not sure what chandwickandhacks.ca is or how to contact them. I've contacted cuisinart and they don't sell the clip by itself. I found small parts inc on line but again you have to buy a complete bowl or cover or both just for the white clip. I've bid for over a month on used covers off ebay but they usually go as high as new ones. It's crazy!
  • 3 Answers
I found a key ring, and bent it out until the ends both poked into the holes where the clip was lost. I want to find a replacement clip, but this fixed the problem of putting it together each time it is turned over!!!
Posted on Jul 18, 2010
In my area, Hamilton, ON., there is a small appliance repair shop called "Hacks". They service all small appliances including my Cuisinart DLC 8 Plus. . Perhaps there is one in your area you could call.
Posted on Nov 27, 2008
  • mhughes7 Nov 28, 2008
    The reason I suggested a repair shop is that they sell OR CAN ORDER parts. Try chandwickandhacks.ca. I have purchased parts for my Cuisinart from them. I'm sure they'll be able to help. Good Luck!.
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
The plastic clip on the Work Bowl Cover with a feed tube fell off
I just encountered the same problem and cannot figure out how to get the clip back on. Did you ever solve this problem? If so, I would love to know how.
May 11, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
Cuisinat DLC 8 Plus Bowl won't unlock
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Have a very hard time to snap the top on the food processor same to take the bowl out
thank you for the follow up
the only way to solve my problem for an older model cuisinart basic is to buy at Le centre du rasoir a new bowl and cover for the model DLC 10 that should fit
have a good day
Sep 07, 2008 | Cuisinart DLC-5 Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Brand NEw DLC-8 not working.
If a part of the work bowl is damaged, it will not properly trigger the motor. Replace the workbowl (original DLC-8 parts not available, but an expensive replacement workbowl is available).
Apr 02, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
343 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
