DVD Burner not recognized
Glenn,
I have found the problem with the DVD Burner. I can plug both the power and the USB in and nothing happens. If I pull the USB cable part way out of the burner and push it back in it will recognize it. However, if you restart the computer you have to repeat that procedure. I have already changed USB cables and that didn't help, so I believe the socket for the USB cable in the burner has a loose connection. Charles
    Scholar:
  • 132 Answers
Charles pull the burner apart are you any good with a soldering iron put in a new fitting glad to here you have settled your problem all the very best mate glenn.........
Posted on Nov 17, 2008
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Not recognize
Update your windows and the restart you pc after plunging out from electricity for 3 minutes
Oct 15, 2013 | LG GSA-2164D (8801031211579) DVD±RW Dual...
I was given a Gear Head Mobile slim burner with the 3 prong usb connector. Could you explain how the burner connects to my pc?
Hi slamalot35,
1. The content you are pertaining to is the USB 'Y' cable. like the image below.
2. Connect both USB Type A (Male) to your laptop or desktop it will require two usb ports. Sometimes your external drive can be detected if you plug only one USB Type A (Male) but most of the time it wont, it will require additional power.
3. Plug the USB Mini 5 to you external slim dvd and wait for your computer to recognize the device.
4. Double your My Computer and look for a DVD RW.
Hopefully this information helps.
Thank you for using FixYa.
Aug 24, 2011 | Computers & Internet
My computer does not recognize my 24x dvd+/-R.
HI AMR450.
YOU SHOULD BETTER TO CHANGE THE USB CABLE .
STILL IT IS HAPPENNING SAME >JUST DISSABLE YOUR FIREWAL AND ANTIVIRUS IF RUN IN YOUR PC>THEN PLUG AND PLAY YOUR DVD RW.STILL IT IS SAME > UNINSTALL THE FIREWAl if have you in your pc .
same problem >go for BIOS>eneble all the USB port >and save it.
if not run, should pnp another dvd from any source for text .If that dvd runs well think your dvd should change.
think it will help you.
shibuda
Nov 24, 2010 | Gear Head 8XDVDEXT DVD External Slim...
IHOOK UP THE BURNER TO MY COMPUTER BUT NOTHING
Try a different USB port. Check if other USB devices are found when in that port.
Unplug other USB devices (keep your keyboard and monitor attached) and check if the device is recognized. Since you indicate that you used the front port, you may want to check that the cable between back of the port to the motherboard is fully seated on both sdes. Make sure that the OS hasn't been set to turn off the previously unused USB ports (this is a security and power-saving option).
I hope this helps.
Dec 29, 2009 | Sony DRX-830U (027242700338) DVD RW Dual...
I need the installation cd for my dvd rw
There isn't a installation CD for the E 40L. I have the same one and Windows has default drivers it will assign to it. The only thing that comes with the burner is bundled DVD burning software and DVD viewing software. The burner is basically Plug and Play (plug it in the usb and Windows will recognize it)
Oct 10, 2009 | LG GSA-E40L Burner
External DVD burner not recognized.
"I got it from a relative that couldn't get it to work either", Could be faulty ...
Mar 01, 2017 | Computers & Internet
Computer wont recognize USB DVD Burner
TRY CONNECTING THROUGH DIFFERENT USB PORT IF NO GOOD CONNECT BURNER AS NORMAL SHUT DOWN COMPUTER THEN REMOVE POWER FROM REAR OF TOWER WAIT 30 SECONDS THEN RECONNECT SEE WHAT HAPPENS START WITH THIS THERE IS MORE COMPLICATED SOLUTIONS THAT I CAN THINK OF BUT LETS KEEP IT SIMPLE AT THIS STAGE AND SEE HOW YOU GO TRY THESE OPTIONS AND IF NO GOOD LET ME KNOW AND I WILL TRY TO ASSIST YOU FURTHER GLENN
Nov 14, 2008 | Computers & Internet
This dell 4600i does not recognize anything i plug into it
First you need to check that you have usb activated in bios.....mostly its F10 at start up or DEL key to enter bios verify that it has been activated
go to device manager and check if it has any ? ! on any of the usb devices
keep me posted
Cheers
Nov 14, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
