Question about Dell Inspiron 6400 Notebook
DELL inspiron 6400 laptop screen turned black
After I switched on my laptop, nothig showed up on its screen. When I connected the laptop to an external monitor, it worked fine. It seems there is no power supply to the monitor, I'm not sure though.
How do I know whether the LCD is bad or the inverter?
Kindly advise.
Ankit
  • ankit_9 Nov 17, 2008
    thanks for replying.
    I already tried the fn+f8 thing, it didnt work. Looks like its the inverter prob. In that case, do I need to replace the inverter or just the coil can be replaced?
    Any suggestions, where to get a used inverter for the LCD screen?
    Ankit.
    I have already opened up the screen and the inverter. I'm now looking for a replacement inverter to check the screen.
    thanks again!
  • Dell Master
  • 4,806 Answers
This sounds like a classic case of inverter problems, it could be just inverter coil thats gone which is an inexpensive repair, if it is the inverter then its a bit more.
try the Fn the F key that shows two tv screen icons, it may just have switched to external mode by accident
good luck
Posted on Nov 16, 2008
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    the best thing is to have a look around a choose a reputable PC repair store, they will be able to tell you if its the coil or the inverter itself and how much it will cost to repair.
    If you don't mind having a go at it yourself you have to take the laptop appart to be able to remove the lid and disconnect the monitor plug and wireless wires, then you have unscrew the bezel ( the front plasic cover ) to reveal the the inverter, its an elongated circuit board, the coil is also on this board and its this board that has to be repaced, you can have a look online for the right inverter by laptop make and model.
    I you do decide to do this yourself you will encounter losts of screws! make a small diagram or note about where these screws came from
    good luck
I have replaced my dell inspiron 6400 screen cover. Now my wifi connection does not work. I am getting a message "no wifi networks found". Manual diagnostics tool shows "scan test"...
1st : check if the wireless capability of your notebook is enabled. There might be a switch or button that needs to be pressed to enable the wireless capabilty of your notebook.
2nd : check the device manager if the wireless network card is listed with no question mark or exclamation point. if it has, then reinstall the driver.
3nd or the wireless card might loosen.. at the bottom of your notebook, you will find several screws there. look for a small box usually with 2 screws. Open that up and you should see a black and white cable connected to a small card. Ensure those 2 cables are connected. Ensure that the laptop is powered off when you do this. Then try it again.
Hope that works.
~jash
Sep 13, 2011 | Dell Inspiron 6400 Notebook
I HAVE INSPIRON 6400 LAPTOP. ON SWITCHING ON SCREEN SHOWS BLUE & ORANGE WORDING OF DELL LOGO AND THEN GOES BLANK. IT WORKS WHEN USING AN EXTERNAL MONITOR.
Run the LCD BIST Test
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=04&l=en&s=bsd&dn=1092705
If it passes, replace the motherboard, fails replace the LCD
May 17, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 errors 0244 and 1A44
Sounds like a bad drive but it may still have the data on it (hand it over to a professional).
Next time, don't forget to do your backups so you don't have to worry.
JOAT
Nov 10, 2009 | Dell Inspiron 6400 Notebook
DELL inspiron 6400 not switched on
This is a no boot issue. Youre saying that you can perfectly run the PSA diagnostics but doesnt load Windows rather it stays on black screen, meaning the boot loader of Windows failed to load. You need to reinstall windows on your computer
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Black screen dell inspiron
simple, insert the CD XP boot it on using it, then repair wait for a moment, then it give you options which is either to repair your OS or install it again. thats it
Dec 14, 2008 | Dell Inspiron 6400 Notebook
Problem with display on Screen
Try ajustiong the resolution and advanced settings.
Jun 24, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
991 people viewed this question
Alun Cox
