Question about GE GSS25JEMWW Side by Side
No power to the water dispensor or other buttons on the door
I have a GE side by side Adora model dss25kgraww (Home Depot) it's about two years old.
The panel above the water dispensor (ice, light, lock, water) will not light up anymore. You can push any of the buttons and nothing happens. My wife said " the light flickered and the bulb broke off" now the panel appears to no longer work. I removed the socket for the bulb and replaced with a new bulb. When trying to use the dispensor nothing happens. Any idea what happened? How can I fix it?
  • 2 more comments
  • davistod Nov 17, 2008
    Thanks for the fast reply. My bet is that the control board failed. She said the lamp flickered while getting ice. She was able to get ice but no water. She tightened the lamp by hand and the bulb broke off in her hand. I guess it may have caused a short or something.
    Can the control board be replaced by myself or does a service man have to repair it?
    Thanks again for such a fast reply.
  • Sebasti1 Nov 19, 2008
    I have a similar problem with a GE, model # DSS25MSSESS from Home Depot. The water and ice dispenser stopped working even if the freezer still makes ice cubes. The light bulb also stopped working.
    I replaced the whole control panel (part # WR55X10423) and the light bulb but it still does not work.
    Could you help me ?
    Thank you in advance.
  • davistod Nov 22, 2008
    The Control Board came in today. Plugged it in and we now have water and ice again.
    I paid $59.95 plus shipping. It sure beat paying a service call (120.00 )and labor plus parts.
    The Control Panel I replaced was behind the push buttons on the freezer door. Very easy fix. The three plugs just unplugged and replugged.
    Thanks for the help.
  • mcaillet Jan 11, 2009
    I am having the same problem with the control panel for the ice/water/light not working. How do you pop the control panel off to replace it?
  • 251 Answers
It has to be one of many things the Control Board or Double Outlet Water Valve,Dispenser Door Solenoid
Here to help
Posted on Nov 16, 2008
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
My refrig is not cooling and the water dispensor is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
May 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Water Dispensor drips
You probably need a new water valve in the back of the fridge the valve is not shutting off completely  replacing valve will correct this problem
Nov 13, 2008 | GE GSS25JEMWW Side by Side
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
GE GSS25JEMWW Side by Side Logo
197 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
