Question about Memorex MVD2042 DVD Player
My Memorex MVD2042 Progressive Scan DVD player says no disc
One suggestion I read said to clean the lens. Where is the lens located?
The lens is located on the inside. you will have to remove the top casing, once you do you will see the dvd player, then you will need to remove the top bar that runs across it. you will see a yellow sticker on....undo the screws and the you will see the lens.....
Posted on Nov 28, 2008
My DVD Player says there is no disc. I have it pluged in to Color Stream progressive on my TV?
Posted on Mar 08, 2009
How do you find free solutions on your website?
The possible problems are dirty/dusty optical lens or totally fault/defective optical lens..please try to used CD cleaner first to clean the lens,.
Jan 02, 2012 | Memorex MVD2042 DVD Player
Dvd won't play my dvd's. keep saying no disc or wrong disc. what is the problem
  • Hi, Sounds like the lens is just really dirty. Go buy a leans cleaner disk and run it through the DVD player two or three times to get the lens good and clean. Repeat about once a month to keep the lens clean and running properly. Sometimes you need to run it through 3 or 4 times to get the lens to read again.
  • These disks I speak of have little bristles on it that "sweep" the lens clean. I use them on all my disk players and they work real well.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 26, 2011 | Memorex MVD2016 DVD Player
Psan error
progressive scan error turn off progressive scan
Sep 11, 2011 | Memorex MVD2042 DVD Player
MVD2040 SAYS FOR ALL DVD NO DISC OR ALWAYS LOADING OR STOPS THEM.
try put a vcd disc or cd audio disc, if it reads, then your lens subject for replacement, partially burnt.
Jan 01, 2010 | Memorex MVD2042 DVD Player
My DVD Pler loads but in aminute or so it says no disc
Try another disc, does this happen with all discs? the optics are most likely failing, did you try a DVD lens cleaner and also try canned air?
Mar 08, 2009 | Memorex MVD2042 DVD Player
DVE not loadong
try cleaning your lens on the dvd player
Oct 03, 2008 | Memorex MVD2042 DVD Player
Pscan - split screen
The switch on the back of my Memorex DVD Player was set to Progressive Scan (ON) Turned off, worked!!!
Mar 15, 2008 | Memorex MVD2042 DVD Player
Instruction manuel
Here is the link to the memorex site. http://www.memorexelectronics.com/html/product_detail.php?PID=43# You can download a .pdf version of the manual.
Feb 15, 2008 | Memorex MVD2042 DVD Player
Memorex dvd player model # mvd2042
I'm having an identical problem with my very new "Memorex DVD". After trouble shooting everything suggested in the manual, I'm on my way to buy another "new" dvd player. Definately will not be Memorex.
Jan 04, 2008 | Memorex MVD2042 DVD Player
Memorex DVD player
I just had this problem and did a search on the web and found the solution. There is a switch on the back of your DVD player for Progressive Scan. Turn it off and the message will go away and your player will work.
May 28, 2007 | Memorex MVD2042 DVD Player
Memorex MVD2042 DVD Player Logo
256 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
