Question about Whirlpool Duet GHW9150P Front Load Washer
F30 error code on whirlpool front load washer ''Duet''
What can be done about the F30 error code?
  • 1 more comment
  • vickybecerra Nov 17, 2008
    I have gotten this failure code also and a f 11 and door lock failure code
  • kcpoulin Nov 28, 2008
    my washmachine stopped working and a f30 came up, can this be fixed without a repair man, this happen once before and we we gone away and when we came back a few days later it worked
  • janedoesimmo Jan 17, 2009
    I have the same problem. My washer is less than 2 months old. I now have a full load of slightly wet dirty clothes and the nearest laundromat is 30 minutes away. The soonest the service people can come out is 5 days from now. I'm not sure why I went and got another duet after the last one only lasted 5 years with very little use ( 2 loads per week).
  • 370 Answers
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
How to reppair a F30 error code
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa!!
Nov 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F30
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
Here is the service manual.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,564 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
