Question about Asko 24 in. D3120 Dishwasher
Asko d3120 fills then shuts off
I turn on the dishwasher, can hear it drain and then fill, then it shuts off, filters are clean
  • 3422 Answers
SOURCE: Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
  • 28 Answers
SOURCE: asko D3120 I have resolved the problem of pum
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Posted on Jul 27, 2009
  • 7 Answers
SOURCE: Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Posted on Sep 01, 2009
  • 121 Answers
SOURCE: Asko d1776 dishwasher not filling
first thing id check is your incoming water fron sink make sure valve turned on- hot side. should be under sink. also some models when you first turn unit on they drain so make sure and give it a few minutes before you assume something is wrong. if valve off then thats your problem,if it is on, then i would remove the btm access panel and check your water valve. if you have a ohm tester valve can be ohmed out if you get a reading in ohms that means water valve is good. if you test valve and no reading from valve then you have a bad water valve. if bad valve roughly 45-85 for part and labor would be around 75-125 more or less depending on were you live and what servicer you use. hope this helps and gives you ageneral idea of how much it would cost to repair roughly
Posted on Sep 16, 2009
Hi, my D3120 Asko dishwasher starts but stops after about a minute. If I press the start button again, it starts but stops again. What's wrong?
When it shuts off, is there still water standing in it? First, you need to know if it stops because the pump (that pumps OUT the water) is working. When it stops, do you hear the water draining? ...(through your sink drain). Many times the tube that pumps out the water is clogged from food matter stuck in the drain tube. If you had a disposal put in recently, there is a plug that has to come OUT of the disposal to hook up the dishwasher drain.
Jan 02, 2015 | Dishwashers
Goodluck,
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
For 6 mos. now, my dishwasher has begun to leave this white filmy, cloudy residue on all my dishes. It has ruined calaphon utensils and glasses I have had for 14 years. The detergent has always been the...
Hi
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Hope this helps......
Daniel
Feb 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore 17379 dishes are not clean after running a cycle
Hi
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
Glasses in upper rack not cleaning
Hi
Jan 30, 2011 | Maytag 24 in. MDB5600A Jetclean II...
Asko 24 in. D3120 Dishwasher Logo
55 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
