Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Jet dry not draining no clog as far as i know
My jet clean/quiet pack will not drain after cycle is done, is the dial junk?can it be replaced someone mentioned it was the dial/relay
  • 2 more comments
  • jmkl3 Jul 09, 2008
    jet dry quiet pack will not drain, keeps water in the bottom, how to fix?
  • pitt1ja Aug 03, 2008
    same problem will not drain, no clog.
    Maytag Jetclean
    model MDBD850AWQ
    serial# 27779057ZS
    thanks
  • w2sgb Aug 18, 2008
    I have the same problem: no draining using any cycle. I can blow bubbles back through the drain hose so no blockage. JetClean Quiet Plus; Model DWU8702AAM, Ser. No. 30306237QM.
  • houseroad99 Dec 28, 2008
    my dishwasher hasn't used any jet dry in 2 months ? Any answers
    President:
  • 1,314 Answers
I needed all your all your serial num its important 17
Posted on Jan 04, 2008
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Water is not drainig from bottom of dishwasher
normally its two things, 1 over sudzing or 2. or a semi clogged drain. over sudzing can be caused by using jet dry and let say a cascade with a jet dry shine that can cause the unit to have alot of soap. in some units the way it operates is that when the sensors see there is alot of soap it will keep rinsing to get out soap until it cant rinse no more.reduce with a regular soap with no extra jet dry,your drain may has to be cleaned it might be a slight blockage. let me know how you made out.
Feb 23, 2010 | Dishwashers
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Elite Quiet 2 Model 45862402
When the machine drains can you hear the water going into the drain? I thinking your pump is not pumping from debris or the drain hose to far in the drain. The kick panel below the door has three screws 1/4 or Torx T20. There is a clean out left side of the pump, the large screw handle removes and does have some water behind it so wrap a trash bag around the clean out before opening.
Oct 22, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
437 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
