Question about Sharp 32K-S400 32" TV
Lost remote and need to get to the menu
Is there a way to do this without a remote?
I need to access the service menu without the remote
You can't enter its service mode, without a remote control. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Samsung LN37A450 LCD TV
Navigate DVD menu without remote
You can't navigate the DVD menu, without a remote control.
Apr 23, 2013 | Sylvania NB111 Remote Control NB111UD
We lost the remote and I can't change the air to cable without going to menu so I need know what I can do or what codes to use the model is gpx kl10085
I believe you need to hunt on Ebay for the correct remote. Most Universal remotes won't do what the factory ones can do.
Jan 31, 2013 | Televison & Video
Ferguson F1905lvd t/v no remote control and need to re/tune
As there is no Menu button on the front panel of your TV, to perform an auto tuning function, you must have its remote control. Without remote control, it is impossible to get in to this menu option.
Jun 12, 2012 | Televison & Video
Can I brighten the picuture my goodmann tv without a remote control
As there is no Menu button on the frnt panel of your TV, you can't do any picture adjustments, without its remote control.
May 31, 2012 | Televison & Video
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
Nov 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
Sharp 32K-S400 32" TV Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
