Question about GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer
Washer make a clicking noise
My washing machine makes a clicking noise during the wash cycle. Everything works normal except for when the agitater turns counter clockwise during the wash cycle. No problems during the wash cycle when the agitater turns clockwise. Also no problems during the final spin cycle which turns counter clockwise. I only bought my washer 4 years ago. Thank you.
  • 14 more comments
  • Jason Zurenda Dec 01, 2006
    I pulled off the agitator and found some pennies lodged in there but the noise still continued. Even with the agitator off the clicking noise would continue in the counter clockwise motion but not in the clockwise motion. Maybe something is wrong with a gear in the transmission for the counterclock wish motion.
  • Anonymous Mar 13, 2014
    Noise whist during wash cycle sounds like bearing noise
  • Anonymous Mar 15, 2014
    Noise during wash cycle
  • Anonymous Mar 16, 2014
    During wash cycle makes beeping noise
  • Anonymous Mar 18, 2014
    may tag washing machine started making loud noise during night. I unplugged it and its still making a loud noise when not in use.
    During spin the machine makes clicking noise
  • Anonymous Mar 19, 2014
    Turns on, timer counts down, lot of clicking doesn't fill or spin
    During washing cycle, it sounds normal in one direction, but makes a grinding noise (what I would call) return. Suggestions?
    buzzing noise when plugged in, my aunt says the washer turns on at night. but when I when to check what the problem was. I noticed that as soon as I plug the cord in, a buzzing noise starts and wont stop. I turn the cycle nob to any of the cycles and it doesn't do anything. no a single thing.
  • Anonymous Mar 20, 2014
    It washes clothes good but shakes badly during spin cycle and clothes are too wet. it worked great for the first year or two.
  • Anonymous Mar 21, 2014
    Clicking noise during agitation cycle
    Eeverytime the washing machine hits 21 minutes in duration it then jumps back up to 25 minutes.
  • Anonymous Mar 22, 2014
    high squealing noise
    model WPRE6100GWT
  • Anonymous Mar 23, 2014
    machine is working but makes loud noices during wash cycle
  • Anonymous Mar 24, 2014
    THE WASH CYCLE SEEMS TO START BUT THE DRUM DOESN'T START TURNING. IT STOPS MAKING NOISE AND THE COUNTER JUST COUNTS DOWN TO 0. IT HASN'T WORKED SINCE THE FUSE BOARD WAS TRIPPED, I ASSUME BY THE WASHING WACHING FAULT.
    President:
  • 878 Answers
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
SOURCE:
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer Logo
1,817 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
