My laptop is coming up with an error message when I try to turn it on. I have tried to use an Sata external enclosure to transfer the data but it will not allow me to access any data. Can you please advise me of any ways in which i can retrieve the data without wiping it from the laptop.
SOURCE: iomega 500 Gb external hard drive - won't allow transfer of large files
go into Device Manager and into the properties of the drive, then Power Mangement and tell Windows not to allow power to be reduced to save energy.
SOURCE: unable to enable dvd writer
go into System Maintenance add/remove hardware and delete DVD , then reset to enable search for new hardware. should resolve.
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
SOURCE: I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
