Question about Sony KV-27V40 27" TV
Won't turn on
Suddenly turned itself off,won't turn on. timer/standby blinks 4 times.
thanks
  • mary_tanis Nov 17, 2008
    Thank you for you input but this is way beyond my capabilities !! I think it's time for the service pros.
    Again,thank you.
    Brigadier General:
  • 6,966 Answers
Sony has self-diagnostics built-in to the TV. This is as you noted indicated by the blinking LED light(s). Initially and based on conventional TV sets, the four (4) blinks a vertical failure. This would normally mean the vertical IC requires replacement. In some Sony versions/models, the IC would be LA7835 but this has to be confirmed on the actual part from the PCB. There are instances where the IC is not defective but the diode and/or limiting resistor from the FBT that provides the ~+28VDC supply to the vertical IC that could be defective. As you will note, this is rather a technical repair and not an easy user action. This of course would require a familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 17, 2008
No picture when turned on, standby timer blinks 4 times then stops then repeats itself, blinking 4 times again
I would certainly go in there and check out the audio amp IC. Been a while since I repaired one of these.....The audio amp in this case may have a built in timer inside the same IC. As we speak, I do not remember the location. Please note it is on a heat sink and think it is a TDA series. When you find this IC, it will cross with a NTE semi conductor . You will see a schematic telling you it is, an audio amp with built in timer. Thanks for asking and show a few hands of support.
Nov 30, 2010 | Sony KV-27S45 27" TV
Sony TV shuts down
check for D616 open or Q603 short.
sometime D501 leaky.
Apr 22, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby light blinks and tv won't turn on
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Dec 27, 2008 | Televison & Video
Trinitron suddenly turned itself off.Now doesn't go on.
Hi again,
I was just checking similar problems and saw that you posted twice.
Pls see your other post here with my proposed solution.
Nov 15, 2008 | Sony KV-27V40 27" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Televison & Video Logo
475 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
