Question about JVC XV-SA70 DVD Player
Tray Open not detected
System is always in Loading mode. Once tray has opened, the display does not indicate Open as it should. If I manually push on the tray, it self-drives closed but still says Loading until I hold the power button in for several seconds until the system goes into Standby power mode. If I power on with Stop and Play buttons pressed, the display indicates: TEST 06 J and does not change to anything else. Is this likely a sensing issue, or a firmware issue? I have opened up the unit, have removed the player assembly, do not see anything obviously amiss ... dusted it off although did not see anything obviously dirty. If it may be a firmware issue, can someone advise how I can query the current rev installed, and how can I see more information about the self-checks that are being performed? Thanks; Larry. p.s. I know this is similar to some of the other problems posted here, but there have not really been any definitive or specific answers posted.
  • sa72 Nov 05, 2007
SOURCE: HELLO
I also the same JVC XVS-500 DVD that flashes "hello" and then turns off. I took it apart and cleaned it and tried the test and reset; no change.
Posted on Jun 15, 2008
  • 1894 Answers
SOURCE: Model XV-N652S DVD player. When the
leave the unit off for 3 or 5 hours (plugged off from wall power)
and then switch it ON back.
this will get solved
Posted on Jul 24, 2008
VOTIT
  • 2071 Answers
SOURCE: Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 28, 2008
  • 6 Answers
SOURCE: DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Posted on Dec 27, 2008
  • 11 Answers
SOURCE: DVD tray will not stay closed (empty or loaded) on
get a new dvd player
Posted on Oct 16, 2009
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
Will only open tray # 4
Check its loading belt. Replace it.
Jun 05, 2012 | Philips MCM530 CD Shelf System
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
Cd door will not open
same thing happened to me. turn the system off, unplug it. then back on and after you switch to CD mode (for some reason the CD tray will not eject unless in CD mode), once the system tries to lock on to a specific CD tray, hold the eject button down for 5 seconds. that worked for me. may have been dumb luck but can't hurt.
Aug 27, 2008 | Venturer CD2770 CD Shelf System
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
JVC XV-SA70 DVD Player Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
