Question about Toshiba Satellite L20-S310TD Notebook
Cd drive problem
I recently got my cd drive replaced,4 weeks later and i,m getting "power calibration error" when i try and burn a dvd,and also get "try other disks",i been using 3 diff brands since the trouble started,same problems,it says the device is working ok when i open the properties in the drive,it burns cds but wont burn dvds,i,m getting annoyed with it,i dont wanna end up buying another drive.
my laptop is a toshiba satellite l20
cd drive is matshita dvdram uj 841S
i was told maybe the drive needs reinstalled but i have no idea in doing so and i,m not very computer literate to be fair,so any diagrams would be welcome or a complete list of tests to do,with explanations in the test,i,m at my wits end with the cd drive as i need to get important stuff off my laptop
  • jasonmcl Nov 17, 2008
    hi there,scuse my total ignorance regarding the matter,any chance in telling me how to do it,i,ve no idea where to find the device manager,and what to look for,and what to do,sorry bout this,i,m really computer stupid.
    system - microsoft windows xp home edition version 2002 service pack 3
    intel (R) celeron (R) m processor 1.40 GHz
    1.40 GHz,448 mb of ram
    hope this helps you,many thanks for trying to help me,really appreciate it.
  • Toshiba Master
  • 4,806 Answers
Uninstall the cd device in device manager then reinstall, but, instead of asking the pc to do it automatically tell the pc to search the internet for the drivers
hope this works for you
Posted on Nov 16, 2008
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    i need to know what operating system you are using before i can instruct you on how to get to the device manager
    regards
  • Lee Hodgson
    ok here is how to get to "device manager" right click on the "my computer" icon, select the properties tab (at the bottom) this will bring up a new window with muliple tabs "device manager" is there on the top row and select that, look down the list until you find cd roms click on the + and it will drop down to reveal the cd/dvd, right click and unistall, it will dissapear from the list.
    Reboot the PC and let if find the hardware again, i might prompt you to install drivers, just click next until your done
    I hope this helps
    kind regards
I'm getting a calibration error every time I try to burn a dvd
Hello Triir,
To get rid of calibration error you have to perform following steps :
1. Click Start
2. Select Control Panel
3. Click on Administrative Tools
4. Click on Services and browse your way down to IMAPI CD BURNING COM SERVICE right click (on IMAPI) then select properties in the middle of the window, it will say start up type. Click on the arrow to the right and select disabled. make sure you click APPLY
May 09, 2011 | Lite On SOHW-1633S DVD±RW Dual Layer...
Cannot write onto CD or DVD
try updating! Nero version 7 is old and cannot work in XP with any upgrade past sp1 If you have Vista now that is another reason to upgrade Nero There is a version 8 now
Jul 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Not able to write dvd on my lenovo3000Y500 laptop
A power calibration error is caused by the inability of a DVD-RW drive to use a DVD-R or DVD-RW disk, it first writes a bit of a data on the DVD then uses it to calibrate itself for the position of the lines. This however can be caused by a number of reasons, so try the following options one after the other, If option 1 does not work, go to option 2, etc.
1:) Matshita has problems with some cheaper brands, get yourself a very known brand DVD as a test like pioneer or tdk
2:) Using a higher speed than the media is meant for, try lowering your burning speed in nero, try the lowest even, let's see if helps
3:) You have a Lenovo as you say. If it comes with Sonic, please uninstall Sonic first, then uninstall nero, then install nero again. Sonic and nero tend to conflict. But even if you do not have Sonic, reinstall nero and apply all new patches.
4:) If option 3 did not help, update the firmware, that helps in a lot of cases.
5:) If even option 4 did not help, disable IMAPI Service (Work's in most cases):
- Launch Control Panel -> Administrative Tools -> Services .
- Browse for "IMAPI CD-Burning COM Service", Right-click on it - and select properties.
- Change Startup Type to Disabled.
- Click Apply and Reboot.
6:) The burner lense needs cleaning, please don't attempt this at home if you are not a mechanic, take it to service they will clean it.
7:) Drive failure, or drive burning out -- then it needs to be replaced, if none of the above helped that is.
If you overlock your computer that can also cause this problem but since you use a laptop I assume you did not overclock it. Let me know if any of the above helped and what the results were.:)
Feb 14, 2009 | Computers & Internet
Power calibration error
change the cables of dvd drive, also check power
Sep 28, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Power calibration fix for a Matsushita UJ-831B. My drive will copy a CD or DVD but it fails to burn either, and says power calibration error
Try to swop the disc that you have for another one-it will very likely burn to the the replacement.Some discs are troublesome.
Jul 23, 2008 | Panasonic Computers & Internet
In the past some burns did not like some makes of cdr's. Ask a friend for a blank cd from a differant manufactor. And be sure that your burn software is set to use the right drive.
Apr 03, 2008 | Computers & Internet
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Numerous errors when attempting to burn dvd's
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Nov 11, 2006 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Toshiba Satellite L20-S310TD Notebook Logo
185 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
