Question about Tanita 2204 Body Fat Scale
Tanita 2204 Scale weight reading problems
I have a Tanita 2204 Body Fat Scale and the weight reding has been in lbs since I started using it. Now the weight reading is no longer in lbs but some other reading I am not familiar with. If you could let me know of any solutions that are available that would be great, thank you.
  • Anonymous Mar 18, 2014
    my us-awe 300g x .01 scale reads "rcal" and when I push cal it just blinks cal but won't read the weight i have on the scale? using the standard calibration weight for the scale
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Posted on Nov 20, 2008
I have a tanita 2000 and my reding has been in lbs now it is in kg, how do I change it back?
Posted on Jan 04, 2009
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Manual and User guide for Tanita 2204 Body Fat Scale
Do not watch body fat scale, watch your mirror. The progress is visible there. Use proper food, exercise a lot and don't worry about body fat scale. This tips helped me: fatlossguide us so if you have 2 min extra time, take a look. best of luck
Apr 03, 2009 | Tanita 2204 Body Fat Scale
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Tanita 2204 Body Fat Scale Logo
854 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
