Question about Linksys Wireless-G WRT54G Router
Linksys WRT54GS not working
I have my linksys WRT54GS router hard wired from the cable box to the computer. It is working okay. It was working okay to provide a wireless connection to my Itouch and then all of a sudden it stopped.
Is there a way to test whether the wireless part of the router is broken by testing it with the computer?
Thanks for your help!
  • 132 Answers
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Posted on Nov 17, 2008
My Linksys WRT54GS ver. 6 Router continuously blinks
Try un-plugging all the cables from the router for 30 seconds, then re-connect them.
Hope this helps!
Feb 04, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
I need help to connect my Linksys WRT54GS router.
you connect your caple from your provider and all connections to your station then start setup by going to the browser and typing for setup you can download a step by step instruction from LINKSYS
Nov 07, 2009 | Linksys Wireless-G WRT54GS Router...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs won't work
Your router might need a restart to begin communicating with the modem again. Remove power from the router, wait a few seconds, then turn the power back on.
Nov 22, 2008 | Linksys Wireless-G WRT54GS Router...
Trying to turn a Linksys WRT54GS into a hub
  1. If you want to set the router to work only as a switch with wireless access point, you may need to get into its setup page and adjust some settings.
  2. Using a computer that is wired directly to one of the router's Ethernet ports, launch IE and type It is the default IP address of the router. Then it will open a window, asking for a username and password. By default, there is no username and the password is admin.
  3. Once you're in the router's User Interface, look for a sub tab called "Advanced Routing" under the main tab SETUP. Then set router mode to "Router" instead of Gateway. In some router's, the choice there is NAT enable or disable. If it is the one showing there instead of Router mode, then set NAT to disable. Click Save settings which is located at the bottom portion of the screen.
  4. Then click on "Basic Setup" and then disable DHCP server. Save the settings then.
  5. Then your modem now will be connected to one of the 4 Ethernet ports of the router.
Hope this helps!
Nov 21, 2008 | Linksys Wireless-G WRT54GS Router...
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
You just needed to Connect ur router to the computer
1>open Internet explorer type and then Enter
2>Leave the username blank and password admin(lowercase)
3>then in linksys page change the Local IP of the router to and then power cycle the network it will not create any problem later
Mar 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
194 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
