Question about Encore ENLTV-FM-HA (CTETVC)
ENLTV- Failed to initialize Hardware. followed steps. STILL PROBLEM!!!!!
Hi, I followed the steps and I may have lost my hardware. I uninstalled my hardware and Windows had located a hardware which "might not work". The hardware didn't work. Now the computer isnt even asking me for a new hardware device and I have uninstalled my hardware and I believe it may have been deleted. (For some ENLTV Program- The problem has now escalated) What do I do now. I am totally lost and in NEED OF HELP. Please see what you can do. I hardly know anything about computers, try and see what you can do. Thanks,
Look at the FAQ in www.encore-usa.com: "When you see "Failed to Initialize Hardware" message, please be sure Video Card driver and Sound Card driver are properly installed by checking Device Manager under Computer Management. If the above conditions are met and you are still experiencing problem, it is necessary to perform a hardware reset procedure on the card. Here's how: power down the computer, unplug the TV Tuner Card from the motherboard, remove the jumper on the card (pin 2 and 3) and then put it back. Power back up the computer and then try to run the software again." It seems that the card have some kind of issue that "hangs" its hardware, you should try also another TV Program like K-TV. Mine did exactly that "Failed to initalize Hardware" but the free K-TV program worked! :)
Posted on May 01, 2007
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: ENLTV- Failed to initialize Hardware. followed steps. STILL PROBLEM!!!!!
Your hardware technically hasn't gone anywhere, it is still inside your computer. However, the drives for said hardware may have dissapeard. Try installing the drivers from the CD, and see if Windows recognizes the hardware then. If it does, follow the steps in the previous solution to reinstall generic drivers. ***DO NOT REMOVE OLD DRIVERS FIRST*** Just select "update drivers" instead. See if that helps. In the meantime, I am going to see if I can replicate your problem, or see if someone else can help.
Posted on Nov 30, 2006
When I want to start it appears this letter "Fail to initialize hardware! Error Code #E0601009
I am Using The XPOD, XDC-700 TV CARD.It is given me replay ErroorCode#E0601009.Please help me that what can i do for it.
Oct 19, 2010 | Encore ENLTV-FM (EN-LTVFM)
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
Failed to intialize render . hardware T&L but not supported by adapter .
it means that you ae not having and separate graphic card , you are using your motherboard's on board graphics adapter
please get any graphic cards like nvidia geforce 7 or 8 or 9
Apr 04, 2009 | Encore ENLTV-FM-HA (CTETVC)
Fail to initialize hardware!ErrorCode#E0601
esse erro leia o manual la ta escrito o porque deste problema por isso o brasil nao via pra frente
Dec 29, 2008 | Encore ENLTV-FM (EN-LTVFM)
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Nov 30, 2006 | Encore ENLTV-FM-HA (CTETVC)
FAILED TO INITIALIZE HARDWARE ????
my computer hang everytime i install enltv.i follow your steps but it also hang.what should i do?pls help me..
here's my email add mikesalen29@yahoo.com
Nov 29, 2006 | Encore ENLTV-FM-HA (CTETVC)
Failure To Initialize Hardware
OK I think your problem may be that you need to install/reinstall the drivers.
Does it show up in Device Manager? If so, Uninstall it, reboot and then reinstall the drivers when, if? XP detects it and asks for drivers.
Hopefully this will sort it. If not, then maybe ya card is faulty.
Oct 12, 2006 | Encore ENLTV-FM-HA (CTETVC)
Televison & Video Logo
4,624 people viewed this question
Top Encore Televison & Video Experts
John Bolton
Tom Chichester
Are you an Encore Televison and Video Expert? Answer questions, earn points and help others
