Question about Sunpak Auto 544 Flash
Flash works intermittantly
Is their a correct setting? I don't understand the dials and how they match with my nikkormat N.or my nikon f100. How do I set up the flash, is that the problem?? This is a Sunpak 544 Gene
    New Friend:
  • 30 Answers
There can be more than one causes.
If intermittent work mean that in, at least, some cases the strobe fires normally and the internal sensor controls the power as it should, then the most probable cause is a diry contact at the either end of the PC cord or a broken wire in the cord. Clean with any gentle method or disconnect-reconnect a dozen times in order to rub off the oxidization, or replace in the latter case.
If it doesn't help then the culprit can be a cold solder joint inside the flash, the repair of which asks for a technician with skills.
If the intermittent work means that the flash always fires, but sometimes with the correct power and sometimes with full power, then the case is more sophisticated, and surely needs a repair of internal circuitry. See the description of such issue for a Sunpak 522 elsewhere in Fixya
Good luck, Laszlo
Posted on Nov 24, 2008
Flash not working Nikon Coolpix L110
The flash, build in the camera, gets its power from the main battery. If the settings are correct, it should work. Try setting the camera to the green auto logo on the main dial. Then in a dark place the flash should work. As soon as your mail dial is on a scene or on manual, he camera won't flash unless you chose it to do.
May 22, 2014 | Cameras
Nikon f100 metering selector is not working
Hi David,
Are you talking about the dial on the right side of the pentaprism? If so I believe that entire top can be removed then replaced with a new/used. Check with Nikon for the part number then have your fingers do the walking.
Cordially,
Apr 03, 2013 | Nikon F100 35mm SLR Camera
Function dial works intermittently on Nikon D100
The inner mechanism may be dirty, "and a professional cleaning may fix that, or the complete dial might need to be replaced.
Apr 02, 2012 | Nikon D100 Digital Camera
Where can I get a 6v battery for my NIKKORMAT EL?
One possible source is http://www.batteriesplus.com/products/563-0/7529-Film-Camera-Battery/47473-Nikon/Nikkormat-EL/1.aspx
Jun 15, 2010 | Nikon Photography
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
Nikon F100 suddenly went dead
Which battery holder are you using? The small one or the grip MB-15? If it is the MB-15 make sure it is screwed in tight. If it is the small one then make sure your batteries are in the correct direction. If that does not work call Nikon Film 1-800-645-6687.
May 16, 2010 | Nikon F100 35mm SLR Camera
I need to find a manual for my nikkormat fs
I don't see a manual for the FS but you can find manuals for cameras of similar vintage at http://www.butkus.org/chinon/nikon.htm
Sep 30, 2009 | Nikon F65 35mm SLR Camera
Nikon F100: Multiple exposures, delayed exposures
Thanks for your email. In the meantime I learned my problems were not uncommon with early production F100s; the culprit is the switching circuitry under the film advance mode dial, which has to be replaced. Essex Camera of Carlstadt, NJ, will do the repair, including general service, at a cost of $ 150. Sincerely,
Tom
Sep 08, 2008 | Nikon F100 35mm SLR Camera
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Lighting
You just need to use the right film, ask your local retailer
Nov 07, 2007 | Nikon F100 35mm SLR Camera
Sunpak Auto 544 Flash Logo
153 people viewed this question
Top Sunpak Cameras Experts
bhargav
Doberman
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
