Only sound from Direct and Stereo settings on Denon AVR 788
I only get sound from the Direct and Stereo settings on my Denon AVR 788. I use analog cables and have it set to analog. Sound is only coming from the front left and right speakers. No sound from center, surround (rear left & right) and SW. What could be my problem?
  • jbgornall
    jbgornall Apr 08, 2013
    Use hdmi or digital input. Also try the simulated surround setting on the back of your remote
You have to use hdmi or digital input for surround sound
Posted on Apr 08, 2013
    Problem Solver:
  • 15 Answers
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Posted on Dec 02, 2008
My denon receiver ( AVR-1508) will only produce sound on the direct and stereo setting
Some details are missing. What source(s)? Analog and/or digital? Test tones work ok? Have you looked at the manual and every control for possible mis-setting, say, EXT In or a Tape selected?
Aug 25, 2011 | Audio Players & Recorders
In cable / sat mode accidentally switched to analog in stereo. i have 5 surround sound and can not get any sound. how do i get out of analog and stereo - i have a denon avr 1911
Carefully examine the front panel indicators for status of switches you DON'T want active.
http://www.retrevo.com/support/Denon-AVR-1911-Receivers-manual/id/23695ci376/t/2/
Register and download it for free at retrevo.com
See Page 17 and consider how the digital audio is assigned (page 46).
Feb 13, 2011 | Denon AVR-1911 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
No sound other than from direct stereo or pure direct. Denon AVR 2808
You can try this reset precedure below, but it sounds like you may have a DSP board problem. This is a new model of Denon, it should still be under Denon's warranrty, it has a 2 year warranty. If this does not help, you need to take it in to be serviced. If it is not under warranty, you will not like the cost of the repair. A new DSP board usualy cost about $300 and then you must pay for the labor. It is not cheap. This reset procedure has been know to work some minor miracles, lets hope it works one for you.
1. Switch off the unit.
2. Hold the following STANDARD button and DSP SIMULATION
button, and switch on the unit.
3. Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Note:��If step 3 does not work, start over from step 1.
�� All user settings will be lost and this factory setting
will be recovered when this initialization mode.
So make sure to memorize your setting for restoring
after the initialization.
Jul 12, 2008 | Audio Players & Recorders
Denon AVR 1803 Receiver lost audio
Make sure your receiver is set to either "auto-select" or "digital" rather than "analog" (button on front display).
May 25, 2008 | Denon AVR-1803 Receiver
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
168 people viewed this question
 Grubhead
Grubhead
