Question about Yamaha HTR-5990 Receiver
No Video when using component Video/Audio cables
I have set V-CONV to ON but I still don't get any video (only sound) when I connect component cables (doesn't matter into which input). Help! DVD, Ninetendo etc won't work....
If you are useing component cable on you dvd, and you dont get video ! Check your setting on the dvd menu. change your video setting from composite, to component.
Posted on Feb 14, 2007
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
Yamaha Receiver RX-V367. Connected a WII to the audio/video jacks in front. Sound but no audio Do I need to select a certain device from input menu?
I am trying to connect my Wii with the component cables to my yamaha rx-v367. No video but sound. What am I doing wrong?
Jun 19, 2010 | Audio Players & Recorders
Using monster
Hi, You will need to go into the menu of the AVR to change a few settings. To get into the menu -
  1. Make sure you are on an input of the TV that is connected to the COMPONENT VIDEO output of the AVR (I imagine you already have this hooked up)
  2. Using the Denon remote that came with the 1907, filp it to the back side and open the door that covers more buttons.
  3. Press the System Setup button
  4. Go into the AUDIO SETUP
  5. Make sure the DIGITAL INPUT ASSIGNED is set to none for the audio input you wish to use for the PS3.
  6. Going back a menu to VIDEO SETUP, make sure that the COMPONENT VIDEO you are using is assigned to the AUDIO INPUT you are using.
That should fix your problem. If you need more clarification or this did not work feel free to post that on this question. Good Luck
Jul 07, 2009 | Denon AVR-1907 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
We have an Akai flat screen tv and a phillips dvd player it is all connected but we have no sound what could our problem be I tried checking all the cords and adjusting the tv settings.
This is going out on a limb, but are you using an s-video or component connection and forgetting to also use sound cables?
Older style A/V cables have a yellow connector for video and red and white connectors for sound. Superior s-video and component connections (which if you aren't using, you really really should) are for video only, and require also using red and white audio cables. S-video is a big connector that looks like the kind used on a computer mouse or keyboard, and component uses three cables, red, green, and blue connectors.
Mar 25, 2008 | Televison & Video
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
No sound when connected to dvd player
If it's only connected with component video cable (Red, Blue, Green) cable set then no audio has been connected. You will still need to run a set of audio cables (usually White and Red). The other option is to use Composite cables (Yellow, White, Red). A composite cable set has the video on the yellow cable and the audio on the white and red. Component video breaks the video into the three channels.
I want you to know that I'm not paid for this, I just like trying to help. If I've misunderstood your question or this information does not solve your problem I'd be happy to try to help more. If you do find this information helpful I hope you'll give it a positive rating. Thanks and good luck.
Jan 01, 2008 | RCA P52960 52" Rear Projection Television
Yamaha HTR-5990 Receiver Logo
121 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
