Question about Compaq Presario 1685 PC Notebook
How to open the case of a compaq 1685
I need to replace the power socket on the rear of the notebook case. I have managed to lift the front console and keyboard, but can't seem to get any further to get to the inside of the rear panel to replace the power plu socket.
Can you help me?
  • 93 Answers
Sorry, I don't think you can replaced the socket by your self, it not just because you even don't know to open it, it also need soldering skills and find correct socket can be fit in the case( must same one used for your motherboard.)
Must take whole motherboard out of the case if you want to replaced the power socket. That's not DIY, that's my job.
Posted on Nov 17, 2008
Which components on hp nc6400 motherboard can cause input power failure
Main component to cause such an issue in the DC socket where you plug the power adapter. This is one of the weakest points in the laptop & usually the first suspect when it comes to input power failure. The socket might either be loose (in which case it will need to be re-soldered), or broken (in which case it will need to be replaced). In either case, you need to disassemble the laptop, pull the motherboard out, & inspect & fix the problem.
Aug 29, 2010 | HP Compaq nc6400 Notebook
I replace new battery. It does'nt take charge. the
If u are able to power the laptop with power from the mains (AC) then your problem is the connection between the battery and its socket and not the battery. In that case power management will not see it as u indicated because there is no connection. You have 2 options:
1. Continue to use with mains only 2. Take it to a techie
May 13, 2010 | HP Compaq nx7300 Notebook
How do i remove the outer bezel on a compaq presario cq61? i need to replace the screen. compaq presario cq61-110sa
1. Take the side door off as usual.
2. Locate the drive door lock inside the chassis.
3. Rotate the lock to the down position to unlock the upper front panel door.
4. Press the indentation located on the lower front panel to open the lower door.
5. Grasp under the bottom of the upper front panel door, lift up, and gently remove from the hooks. (Tip: The upper front panel door has finger holes.)
6. Remove any of the bay components by pressing both sides of the drive rails. There are no screws.
hope this helps...........
Mar 14, 2010 | Compaq Presario Notebook
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
I need to remove and replace the DC socket in a Compaq CQ50-209WM. How do I open up the casing in order to do this.
If you go to the Compaq web site and type in your question it will direct you to a pdf manual on how to remove the DC socket. Most Computer web sitetes offer great help on fixing your computer...
Good Luck Darren
Oct 14, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
HP COMPAG 6715B LAPTOP NOTE BOOK
There are alot of hidden screws on that model. Under the rubber feet, inside the battery case and under the keyboard. Even on the back side there are two screws. Make sure all of them are out before continuing. Since the screws are different lengths, I always use colored markers for the screws and holes. I use the washable markers.
Once the case is off you should only use a zero static, grounded soldering station with temp control. Your old pencil iron won't do. Even with no battery on the board the mother board is subject to static shock. I've had alot of employees try to work on a board and they weren't properly grounded. Of course I had to pay for a new mother board. Unless you're very familiar with this kind of work, I would quit now and turn it over to a pro.
Mar 23, 2009 | HP Compaq 6715b Notebook
Casing
The memory socket is located below and to the right of the keyboard. The panel is to the right of the mouse pad.
The keyboard needs to be removed. DO NOT REMOVE THE KEYBOARD CABLE! Remove the screw located in the middle lof the underside of the n610c. Slide the four tabs located on the top edge of the keyboard toward the space bar. The tabs are located to the right of the esc, the F4, the F8, and F12 key. Using a flat blade screwdriver gently lift the top edge of the keyboard, once it is lifted slide it toward the screen.
The panel covering the memory may require "gentle force" to remove.
Jan 04, 2009 | Compaq Evo N610C Notebook
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Open Questions:
See all Compaq Presario 1685 PC Notebook Questions
Compaq Presario 1685 PC Notebook Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
