Question about Linksys Wireless-G WRT54G Router
Router error 322, router will not connect - Linksys Wireless-G WRT54G Router
  • 4 more comments
  • Anonymous Dec 23, 2008
    followed step bt step several times and still had a 322 error each and every time.
    follow step by step over & over again. still gert the 322 connection problem
  • djdino1 Dec 25, 2008
    hi
    i need detail instructino on how to solve this please ,im running vista,,,please help,,,,
  • limmy123 Jan 26, 2009
    ipconfig
  • Anonymous Feb 14, 2009
    error code 322
  • Jannette Amandy May 11, 2010
    What is the exact error you're getting in the router?
    Genius:
  • 1,124 Answers
Have you been configurating your router with your pc
You must configure your router manually and provide your access code / Login
to be able to set up the connection
Once you it is set up no need to setup for other post connecting though the router
If you still have the msg error go and search for the software for adaptable to your Os.
You will find help here
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Posted on Nov 18, 2008
MrDallasIT
  • 91 Answers
SOURCE: error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
Posted on May 18, 2009
SOURCE: Error 322 instaling a WRT54GS V7.2 linksys router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
jaye_ellen
  • 591 Answers
SOURCE: no connection
After you have checked all connections, modem to router and router to computer, try to get your browser to go to http://192.168.1.1 or http://192.168.0.1 if router is not found, and it is indeed connected and powered up, perhaps your router is defective. NOTE: you did not specify your router type or model)
Posted on Nov 11, 2009
SOURCE: Hi I cant configure my router D-link DIR-300
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
Posted on Nov 26, 2009
  • 10406 Answers
SOURCE: I have tried connecting Cisco linksys router but
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Posted on Feb 21, 2011
How to fix error 322 on linksys wag120n
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Dec 03, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
I receive the 322 error when I´m trying to install my new WRT160N v3 Router, by Cisco.
I think you are trying to install the router using the CD. This CD has a bug. Even if your computer is connected to the router , it will say the computer is not connected to the router and it will give you error 322 or 321.
You can install the router without CD also.
Make sure that your computer is able to go online through the modem only.
connect the computer and the modem to the router and open the set up page of the router.
On the set up page you can change the settings of the router according to ISP.
Click Here for step by step instructions
Feb 01, 2010 | Linksys WRT160N Wireless Router
How do i fix error 322 on a linksys router
this error is either caused by the lan icon is disabled or has a manual ip address.
  1. Access the setup page of the router by launching browser and type on the address bar, 192.168.1.1 and press enter.
  2. When it prompts for the username and password, leave the username field empty and provide password as "admin" (Without quotes)
  3. click on ok. On the main setup page the "Internet Connection Type" should be on "Obtain IP Automatically - DHCP “. Click on the Save Settings button.
  4. Now click on the tab "MAC address clone". Click on enable.
  5. Click Clone & click save settings
Jan 03, 2010 | Linksys WRT160N Wireless Router
No connection
Are you trying to install the router using the set up disc.
Some times you get the error 322 , that shows the computer is not connected to the router ( even if it is connected).
You can set up the router manually without the CD.
First reset the router for 30seconds, then unplug the power to the router and plug it back in.
Wait for a minute and then try to set up the router.
Click Here for step by step solution
Nov 11, 2009 | Computers & Internet
Error 322
When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Nov 01, 2009 | Linksys Wireless-G WRT54G Router
Error code 322 cannot find router, after following installation intstructions.
May 12, 2009 | Linksys Wireless-G Broadband Router
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
Linksys Wireless-G WRT54G Router Logo
501 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
