Question about Dryers
Kenmore Elite HE 3t Dryer not blowing hot air
I cleaned all the lint out of the back (inside) of my dryer, and especially the lint that was collecting on top of the hot air intake tube - the lint was actually starting to burn onto the unit. This must have been what was causing the ''burning / smokey smell'' that was coming from the dryer.
Once we reassembled to unit - the dryer works fine and
the burning / smoking smell is now gone HOWEVER it does not blow hot air now.
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
Thermal cut-off
when the thermal fuse or the high limit pops it's because the dryer is running to hot,all a dryer does is move air,when one of the fuses pops it's from a block from lint either in the lint filter duct or the vent line,if the air can't blow outside or out of the dryer the fuse will blow.if your vent line is long remove it from the back of dryer and stick a leaf blower into the vent line and blow all the lint outside,make sure there isn't a cage or anything blocking the outside hood,then pull out the lint filter,take the dryer apart,remove the lint filter duct and clean it out,also vac and blow out the cabinet and motor,you should do this once a year,your clothes will dry on time,less parts will get damaged from overheating ,your electric bill will be less and most important you won't have a dryer fire.hope this helps,the fuse will keep blowing until you clean out the dryer and vent line.
May 16, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
Dryer runs and drys cloths but dosent cool down and stop
when was the last time you cleaned out the dryer?unplug the dryer,remove the bottom panel,take out the lint filter and remove the duct that it slides into.clean the duct out,vac out the inside of dryer,if you have a shop vac you can put it on blow and blow the lint forwards so you don't ha ve to remove the drum.put that back together and remove the vent line from the back of dryer,if it's a long run blow it out with a leaf blower,also make sure the outside vent is clear before you blow out the vent line,if the dryer can't move the air around it will run hot.
Jun 26, 2010 | Kenmore Elite HE4 Electric Dryer
Elecrtic kenmore dryer; auto dry setting not working propeely
you just might need a clean out,unplug the dryer take out the filter,remove the bottom panel and remove the duct that the filter slides into,clean it out and vac out the inside of dryer,if you have a shop vac that blows on the other end blow the lint forward so you don't have to pull the drum to clean the inside,make sure you blow off the motor alot of lint gets stuck inside the motor,now go to the back and remove the vent line,if it's a long run i use a leaf blower to blow all the lint out of the vent line,first make sure nothing is blocking the outside vent so when you blow out the line the lint is free to exit outside,all the thermostats run off of heat and if the dryer is blocked and the air can't move it will run hotter than normal,the timer can't opperate correctly either.all this will cost you is time and this should be done once a year anyway
Feb 14, 2010 | Kenmore Elite HE4 Electric Dryer
Too much lint is getting past the lint trap. How
if the filter isn't damaged then this is normal,you should take off the bottom panel and use a shop vac to blow out all the lint inside the dryer especially the motorand blow it forward and vac it up so you don't have to pull the drum to clean it,then remove the lint filter and take off the duct that the filter slides into,now go outside and make sure nothing is blocking the flapper like an animal cage that comes with some of the outside vents,if it's clear go inside and remove the vent line,if it's a long run from the dryer to the outside blow it out with a leaf blower,you should do this once a year and your clothes will always dry on time and your motor and other parts will last longer,when the lint builds up the dryer runs hotter and longer and that's what damages the dryer
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats up but cloths stay damp
disconect dryer from electric outlet first before doing anything to it!!
check ur outside exhaust vent on the house, might be full of lint, if is ok then check the duct on the back of your dryer, might be full or lint, take an leaf blower an blow all the lint off the air duct, an also if you are handy, remove the 12 or 14 screws of the back of the dryer , take the back panel off, and on your left side u will see the air port where the hot air comes off the dryer take the aditional 4 screws an clean it
then put it back together
if you still have the problem then u have bad coils
what happens an air restriction will cause the dryer not to work properly, it will overheat an shut off. but am more sure u need coils specially if u never got em replace, maintance doesn't hurt at all......
good luck leave some feedback thanks!
Feb 02, 2010 | Kenmore 73952 Gas Dryer
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
Marvin
Marvin
