Question about Garden
Chainsaw cuts out a few seconds running
It's a craftsman saw, starts ok but cuts out when I press the trigger.
  • 1 more comment
  • Ron Z Nov 15, 2011
    I have the same problem, any solutions?
  • Anonymous Mar 17, 2014
    POLAND CHAINSAW STARTS RUNS A FEW SECONDS THEN DIES. REPLACED FUEL DYAFRAME
  • Anonymous Mar 23, 2014
    Been stored for a year maybe more. It starts but will only run at idle. Saw shuts off when increasing fuel to start cutting.
  • 211 Answers
Hi frado
check the fuel lines,make adjustment to the carb,set the T ,check the fuel filter.Inside the carb,at the fuel pump side there is a screen,carefully clean it.Hope theese help.
regards savumihai71
Posted on Dec 01, 2008
What do you meqan by "set the T"
Posted on Mar 28, 2009
Chainsaw issue
What is the model number of the saw?
It may as simple as a tank vent that is clogged. I have seen this on Poulan saws, and many of the new Craftsman saws are rebranded Poulans.
If the saw has a tiny hole in the center of the fuel cap, try this test. Engage the chain brake, turn the saw on its side so the cap is facing upward, loosen the cap slightly, and start it while a strong helper holds it on a workbench. If it runs normally (don't heat up the clutch drum while the brake is engaged!), the tank vent needs to be cleaned or cap replaced. If it still won't run correctly, it is time to diagnose the carburetor and other areas of the engine.
Let me know if you have any luck getting it going.
Mar 30, 2014 | Craftsman Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
The saw is a poulan 3416 ,2 yr old, purchased new. the problem is starts ok 6 primer pushes idles ok then will either die after first cut or as soon as you pull trigger
Run too lean, this is fuel starvation, remove the fuel line from the tank and replace the filter on the end, check the fuel hose from the tank up to the carb for leaking or cracking.
May 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chainsaw, after runnig ok for 15 minutes, is now running sluggish. So, when i press the trigger the saw runs at normal speed for around 3 seconds then begins to die. I wait for a few seconds then the...
it sounds like a fuel issue. on my Stihl (390 )saw I had that same problem and I found that the fuel line inside the fuel tank was kinked and split and sucking air ( not fuel ). also check to make sure your gas oil mix is correct ( start fresh when in doubt ). it also can be a idle issue ( Fast idle or Slow idle ), but since you just had it serviced - I would look at the fuel line and fuel first. please let me know what you find and if that does or does not solve your problem,, there are a few more things to check. ( also - check to see if the air filter is clean and clear ,, brush it off if dirty ).
c...
Dec 29, 2010 | Stihl Garden
Craftsman chainsaw model number 358.351610 worked ok yesterday. Today it starts, runs then dies when trying to cut. Is there an adjustment I need to make?
there is two adj screws on the side of the saw below the primer bulb. get a small screwdiver flat or phillips depending on the brand, start saw with full thottle and start turning idle screw till you get it to idle then adjust from there
Dec 19, 2010 | Garden
Craftsman Chain saw cuts out
Check the fuel filter for plugging and the condition of all fuel lines. Make sure that all carburetor fasteners are tight. Check the air cleaner and muffler for any plugging. Make sure to warm the engine up before accelerating it. If still not running correctly, try turning the H jet needle about 1/8 turn CCW, which should cause the engine to 4-stroke at speed when NOT cutting, but immediately 2-stroke when you are cutting. Hope this helps!
May 11, 2010 | Garden
Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
963 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
