I turned on my wireless device,but when i try to connect with it,i open the wireless network connection and it says:"no wireless were found in renge,make sure the wireless switch on your computer is on" i don't even know how to make sure of that
Look on your function keys there could be a radio tower symbol. If you have one press and hold the FN button ( left side on the bottom of keyboard ) and then press the button with the tower on it that should turn on / off your wireless. you may also have a switch on the sides or front which maybe turned off also check for that.
SOURCE: connecting to wireless network
Not sure what kind of laptop you have, but on some models check to make sure that the actual physical "switch" is turned on. Usually located in the front or side of the laptop. Sometimes there is a little wireless logo located above the keyboard somewhere. And other times its set as a "function" key. If you see a wireless logo on a F-key (say for example F5), press and HOLD the FN key (FN stands for function, usually located on the lower left of the keyboard) and the corresponding F-key. Hope this helps!
SOURCE: HP wireless problem
When you look at the properties for your wireless adapeter, does it say enabled?
On most laptops you'll have a key that has Fn on it. This is your function key. Hold it down, and look for a key that has what looks like a little radio transmission tower on it. Press that key (while holding the Fn key), and see if you get a pop up stating that your wireless is enabled or disabled (usually it pops up with the no symbol through it).
Try this a couple of times, with a few minutes inbetween to see if you can get it to reenable again.
SOURCE: unable to connect to my wireless system with hp pavilion dv6353us
install software for ur plug in wireless then plug in ur wireless ...not until this point will system find and install....then get online and find driver for ur internal wireless ...download and install.....when u remove ur external and restart system will recognise internal as only wireless and configure ...if still have problem ....and ur problem wont be wireless Itll be getting online....then u need to config wireless differently.
let me know
SOURCE: Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
SOURCE: Cant connect to my wireless network anymore???
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
