Pilot won't stay lit. Robertshaw thermostat for gas log - 1 yr old. Worked fine last season. Turned off for Summer. Will not work this fall. Will hold down pilot for full 60 sec. Pilot lights quickly, good blue flame, but will extinguish as soon as I release the pilot valve. Installed neww thermopile. No change.
  • jplidd Nov 16, 2008
    Thanks for the info. This thermostat uses a thermopile not a thermocoupling. And, I did replace teh thermopile and there was no change. Pilot will ot stay lit when pilot knob is released,
    Problem Solver:
  • 5 Answers
Replace the thermo coupling.. available at most hardware stores.. measure the length or take the old one with you.
Posted on Nov 16, 2008
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
My Majestic DVR36RN gas-log fireplace insert will not start. No ignition when striker is depressed, no flame lit at all. Gas inlet line open, pilot switch to "pilot" as directed. Maybe...
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
Nov 09, 2010 | Heating & Cooling
Floor heater won't light
At the gas valve on the furnace, jump the two connections where the thermostat wires attach to, I think TH and TP may be marked on terminals. If it lights, you have bad wire(s) going to thermostat. If it still refuses to light, you may be looking at a new gas valve.
Dec 02, 2009 | Heating & Cooling
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
1986 Weathermaker SX 150 series, model S85X060-CC-1
There are 4 -steps for full run time to kick in a furnace.. step-1, inducer fan runs & prove thru the air tube which closes a switch and tell the circuit board to go to step-2, the igniter lights the pilot & prove its lit by heating the thermocouple, which tells the circuit board to go to step-3, opens the gas valve to dump gas in, which will light from the pilot light, and prove by a flame sensor metal stick on the last burner , which heats up and tell the circuit board Saying, ok , I've got flame.. step-4. when the box heats up, it closes a switch and turn on the main fan...! (Some gas-valves has a brain -or circuit board on top of them and are real sensetive to moisture..)
Sep 05, 2008 | Heating & Cooling
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
364 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
