Question about SanDisk Sansa c140 MP3 Player
Help! it jsut snowed today and i think it got too cold... i tried turning it on and it had run out of batteries, so i put a new battery in. then all it showed was the normal screens...except there weren't any words. all my songs and everything is like deleted or something and i cant get anything to show up. now its jsut frozen at a typical screen with the battery showing and all...but not words or anything else and it wont turn off and it has all the battery power. i jsut got this less thean a month ago and thankfully i have all my music on my computer, but i dont want this to be unsolveable. please help
Well, i'm having problems with my Sansa c140 also, but with this problem I think I can help, hook your mp3 player into your computer, than delete all the songs, and simply put them all back on, and if that doesn't work, than repost.
Posted on Feb 05, 2007
Could my battery be frozen? Do I need a new battery?
Your battery is not frozen. In cold weather, a weak battery--one that needs to be replaced--may not work. The cold makes an already weak battery even weaker.
Mar 05, 2015 | 2008 Nissan Altima Hybrid
35 HP kohler engine wouldn't start
firstly is the coolant up to strength re freezing ? did engine turn over ? if not the cold can kill a battery so try a jump start to rule that out , keep me posted
Nov 09, 2014 | Cars & Trucks
Turned the heater and car off but fan keeps blowing - now cold air - at full blast. had to disconnect battery to get it to stop
car has electronic issues
tow to an auto electrician or impala specific workshop
burnt out fan motor
faulty climate control wiring or sensor
faulty relay
check if direction flap motors or actuators are working
Apr 05, 2017 | 2004 Chevrolet Impala
My '95 Oldsmobile Achieva is not starting!
have battery and relays tested --leaning toward battery fault
Apr 13, 2017 | 1995 Oldsmobile Achieva
I have a jaguar 2000 S-Type, around 98 k miles. I drive it about 5 times a week for about 1 hour each day. Recently, I parked it in the back as there was a severe snow alert and did not drive it for about...
Check your battery with a volt meter. When it gets cold, the plates inside the battery restrict the amperage needed on your car. Get a fresh battery to avoid the hassle. When the current doesn't flow thru the battery due to cold weather, not even a jump will help because its still almost an open circuit. Keep the new battery warm and install it in your jag. start it immediately to get it warmed up. Check your antifreeze level also. If you need it, only put DexCool in concentrated form during your climate chill. It will mix with the diluted antifreeze in the system anyways. Good luck.
Jan 05, 2011 | 2000 Jaguar S-Type
Hi there - I wonder if you can help us, with the heavey snow today our 2 year old Kia Sportage wont move at all. After not using it all day our battery seems to be dead. I would appreciate any help or...
An good battery is not going to die from 1 day of not being used. And one cold day is not going to kill it either. Something drained it, I think you need to charge the battery and take it somewhere and have someone figure out what is draining the battery while the ignition is OFF. this usually turns out to be an anti-theft circuit malfunction which keeps locking/unlocking the doors.
Dec 17, 2010 | 2005 Kia Sportage
1992 GMC Sierra Won't turn over
You either need to charge the battery, or you've got a bad battery. It's easy to power lights and radios, but turning an engine over, especially in cold weather, takes a lot of cold cranking amps (in other words, a fully charged and good battery.).
Feb 11, 2009 | 1992 Oldsmobile Bravada
How cold is too cold for the S730?
Take the camera inside and let it warm up to room temperature. Get another set of brand new batteries. But first take out the batteries and let it sit for an hour. Without any power it can reset itself. The mini cpu inside is thinking its too cold and won't let it come on. After the one hour of sitting, put the new batteries in it and try to power it up. Cold weather can kill a brand new set of batteries in a matter of minutes. You should try not using your camera when its below freezing.
Jan 09, 2009 | Samsung Digimax S730 Digital Camera
Olypus sp-500z Lens won't come out
If the batteries are cold or the camera senses condensation then it may malfunction. Let it stand in the warm room for 1 hour prior to booting up. cold batteries dont put out the same voltage.
Oct 29, 2008 | Cameras
My I Bulldog won't turn on
mine did the same thing, but when i put a new battery in it would turn on only once then i would have to put a new battery in. I dont know how to fix it yet but that will let you listen to it battery at a time.
Mar 30, 2007 | i-Bulldog IMP-90 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
