My wireless connection is not working but when i plug in the ethernet cable is works. In the F1, F2, F3....keys the symbol for the wireless is not there. I need help to find out how I can get my wireless switch turned on.
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
F1 - E0 EEPROM communication error F1 - E1 EEPROM checksum error F1 - E2 UL A/D error F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match stored value F2 - E0 Shorted touch pad F2 - E1 Keypad cable connection error F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models) F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models) F3 - E2 Oven temperature is too high (Cook mode) F3 - E3 Oven temperature is too high (Clean mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models) F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models) F3 - E6 Drawer sensor open F3 - E7 Warming drawer sensor shorted F4 - E1 Meat probe malfunction - shorted F5 - E0 Door Switch F5 - E1 Self clean latch will not lock F5 - E2 Latch during CLEAN error F5 - E5 Self clean temperature not reached within 45 minutes. F5 - E6 Door is open, but latch is locked F5 - E7 Self clean latch will not unlock F6 - E0 Return line not connected F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure F1 ERC Board failure F2 Oven temperature is too high F3 Oven temperature sensor open F4 Oven temperature sensor shorted F5 ERC Board failure F7 Function key stuck on ERC F8 ERC Board failure F9 Oven door lock failure
If you get an error code, try first resetting the code: 1. Disconnect power for about two minutes. 2. Connect back power. 3. If code re-appears, test and eventually replace faulty part.
Check the function keys (F1, F2, F3, etc) for a "wireless" icon. Then when you have found it, hold the "Fn" key (lower left hand side of the keyboard) first and try toggling the function key until a menu comes up or the wireless starts to work.
Packard Bell Easy Note E2 ---- Fn / F1 Packard Bell: easy-note MV46/008 ---- Fn / F1 Packard Bell MZ36-U024 ---- Fn / F2 Easy note W7730---- Antenna like wireless button on the side of the laptop.
(Press & Hold Fn Key and Press F2 or F1 key) ... :)
There should be a switch on the outside of your notebook that disables and enables the wireless adapter. Sometimes it is a toggle switch and sometimes it is a combination of the function (Fn) key and one of the keys at the top: F1, F2, F3, et cetera. Look for an icon that resembles either an antenna or a computer with sets of lines around it. Once you enable the hardware switch, you should be able to go to your Network Connections and double-click the wireless connection to enable it.
Not sure what type of laptop you have, but look at the function keys on your keyboard (F1, F2, F3). Normally one of those will have an Antennae looking icon, if so then press your fn key and that key and it should turn it on.
the wireless switch isnt actually a switch. its the same as on the travelmate 2410 i think.which means its a little button on the front. but if that doesnt work
you could always activate it from inside the network connections bit on control panel.
regards
matt
it surely is a keys combination. just find the little icon that represents wireless over the f1, f2, f3.... keys... arround those keys and by pressing and holding Fn key and at the same time that wireless key you will enable/disable the adapter...
