Won't read(or burn) blank cd. have reinstalled itunes and followed some other suggestions. still no result.
Is your cd drive listed as a device in My Computer? Click Start/My Computer and see if the CD Drive is listed along with the hard drives. If not that's your problem. To solve it you can remove the power cord, remove the battery, turn the laptop over and remove the one screw on the bottom that holds the cd drive then pull the drive out and put it back in (this is called reseating). Boot the laptop and see if the drive is now listed in My Computer.
If the drive is not listed then you will need to remove Upper and Lower Filters.
Windows 7
To resolve this problem on a computer that is runningWindows 7, use the Hardware and Devices troubleshooter. For more informationabout how to open this troubleshooter in Windows 7, visit the followingMicrosoft Web site:http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooterBack to the topWindows Vista
, and then click All Programs.
If you are prompted for an administrator password or for aconfirmation, type the password, or click Allow.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Now go to the "Did this fix theproblem?" section.Back to the topWindows XP
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
If after all this the drive still does not recognize or will not burn a cd you should try using Windows Media Player to burn something. Also If you had something like Nero as a burner software to burn, try using it.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
SOURCE: CD/dvd drivers missing or malfunctioning
do you have other programs that use the cd/dvd device? sometimes multiple programs will fight for rights to it.
go to the following link and download ccleaner
http://www.filehippo.com/download_ccleaner/
install it and run it.
1) click on tools and uninstall itunes with that.
2) click on registry and clean the registry
3 click on cleaner and clean up the junk
4) reboot your comp
5) reinstall i tunes
Let me know :)
SOURCE: windows media player will not burn music cd
why my windows media burn list isn't burning a cd
SOURCE: When opening iTunes I receive this warning
Try turning off your antivirus and/or anti spyware programs before installing i-Tunes. I had a customer where SpySweeper kept i-Tunes from loading.
SOURCE: using acer aspire 5315.. cd rom recognises cds but
Are you able to read CD's and DVD's using the Optical Drive ?If yes, then it may be a problem with the lens in the drive.It can also be an issue with the software that you are using to burn Cd's ( like Nero ).If you are not able to Read and write Cd's or DVD's and the Optical drive isnot listed in " My Computer" then it can be either a driver issue or registry filters issue.Let me know abt this
The Dell Inspiron 531 is a desktop personal computer with a Microsoft Windows operating system. An Inspiron equipped with a CD burner can be used to record audio discs using Windows Media Player, which comes installed on the Inspiron as a standard part of the software package Dell loads onto its computers. Blank, recordable discs and pre-recorded audio CDs are the only supplies needed for the project.
Read more: How to Burn Audio CDs With Dell Inspiron 531 ' eHow.com http://www.ehow.com/how_6210098_burn-cds-dell-inspiron-531.html#ixzz1XyrRh8L7
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
my dvd rw drive IS listed as a device, it plays cds and dvds AND asks to format blank dvds but not blank cds. there is no UpperFilters or LowerFilters in the right pane of regedit. i have reinstalled itunes but still get the message "The registry settings used by the itunes drivers for importing and burning CDs and DVDs..." i have cleaned the lens with a "torn of piece of paper". i have been implementing various suggestions for several and am at witt's end.
