New harmon kardon avr154 receiver only shows B&W
Just bought a harmon kardon avr154 receiver I connected it to my Infocus In72 projector it will only show everything in grainy B&W.
I am currently using svideo cables and have tried HDMI and analog (yellow) cables all have the same reults (grainy B&W) I isolated the projector and when I connect all my components to the the projector using a Radio Shack "distributor" box it works just fine. Also direct port to port compenent to projector works fine as well. I am stumped!!!!! please help
  • AV4me Nov 17, 2008
    I just tried a Sharp flat screen with the tuner and guess waht it worked just fine! So the problem appears to be with the projector itself.
    Tried all,but not successful sorry to say, I think I will upgrade my projector. Thank you so VERY much for your time and effort. It is greatly appreciated.
  • 4,806 Answers
A good idea would be to auto or manualy tune it into the channel, this may sort the problem out!!
good luck
Posted on Nov 16, 2008
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    check the projector bulbs and all the connections around that area make sure all connections are tight and snug in the sockets and make sure all the bulbs are working correctly
    again good lucl
    Scholar:
  • 181 Answers
Did u changed any settings after u connect your device to the projector.
  • 4 more comments
  • fixyy Nov 16, 2008
    remove all the connections again and try reconnecting it again properly and check out.also check any of the jack where u connect the plug is loose internally of properly firm.
    sometimes loose jacks causes this problem.
    component: These are the Red, Green and Blue phono connection on the back of the unit. This is the best connection available in this unit and it is the way u connect the unit to the TV and u have to say that the picture is stunning; this again is down to the source material. IF you are for example playing a really old movie, where the picture has not been cleaned up then the picture will still look grainy,black and white  but put something like Toy Story, Finding Nemo etc and the picture is gorgeous. You may sometimes see them labelled as Y-Pb-Pr, but essentially each lead breaks the picture down into its respective colours, ie red, blue and green, and therefore by dedicating a cable per colour you get outstanding results.
    the main thing the jacks of the HARMON KARDON RECEIVER should be inserted in proper sockets .so try inter changing the jacks in to another sockets and check it may work.
    RGB Scart: Again you will need a decent RGB Scart connector, before u purchased by component cables this is the way u connect your player, bear in mind that you may have to set the Scart to RGB Scart within the OSD (On Screen Display) (not all Scart leads are capable of RGB connections, so make sure that you get a RGB Scart should you wish to connect via this method) additionally if you TV has multiple Scart sockets, not all of them may accept an RGB signal so you need to do a little investigating by inserting the wires in all the jacks 1 by 1 and checking in which it gives proper picture and colour.
    S-Video: this lead basically split the video into 2 signals, therefore giving a slightly clearer picture than the connection worse than it, which is composite; the composite video connection is the yellow phono jack avoid this form of connection if humanly possible.
    The connections above will put the picture on the screen, but what about audio. There are three methods of audio from this player. The best being the coaxial (orange phono) or the optical connection. The optical connection is literally a fibre optic and when you plug in the cable you can see a red light, it is this light that carries the signal. The other method is using the red and white audio options; again avoid these if possible.
    rate the solution if it helps u.
    feel free for further assistance .
    thanks.
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
When I connect the IN72 to a Digital TV Terminal I see horizontal moving lines on the screen.
the resolution doesn't match. reset the projector settings to factory default and make sure the settings are correct, and if the projector can handle the digital signal. you can also try swapping the cables.
Mar 07, 2010 | InFocus IN72 Multimedia Projector
The image via HDMI does not work in projector Infocus IN72
what is the image from? make sure you have the right in put and that the resolution matches. try swapping cables, too.
Feb 08, 2010 | InFocus IN72 Multimedia Projector
Replacement or buying a new one?.
Hi, this seems to be lamp only, go the menu setup and press service info : then you get the lamp hours used if it is more then 1500 hrs you must change the lamp if less, try cleaning filter then reset the lamp again. if problem persist. lamp has to be changed.
Jan 27, 2009 | InFocus IN72 Multimedia Projector
IN72 Projector problem
My understanding when we purchased our IN72 2 years ago is that there wasn't any additional benefit for Cable box using HDMI since the IN72 does not transmit audio so using component cables for cable was optimized enough. We have our DVD player connected via the HDMI only. Possibly the transmission from cable box through an HDMI is not compatible audio is confusing it? hard to say. Cable HD channels look awesome thru the compenent cables, the max for IN72 is 480i anyway.
We've got 35 ft cables for all 3 hdmi, compenent, and that vcr one too and it's worked great.
Oct 22, 2008 | InFocus IN72 Multimedia Projector
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Aug 10, 2008 | InFocus IN72 Multimedia Projector
Infucos IN72 projector
Hi Ronnel
This is a common Mainboard failure on a Projector.
The unfortunate thing is that the Mainboard will either have to be repaired or replaced.
Apr 18, 2008 | InFocus IN72 Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
IN72
Try using a different cable.
If the response is the same on a different cable , then the Mainboard might be at fault - this machine should still be under warranty and the warranty will cover repairs.
Apr 05, 2008 | InFocus IN72 Multimedia Projector
21 people viewed this question
 Grubhead
Grubhead
