Question about Magellan Meridian Color GPS Receiver
BlueNav sd problem ??
I have been using mapsend bluenav sd chart in my Meridan Color for the last two years and it has been working great, but it started stop the last time I was sailing. I would have to shut down the gps and restart and the map would be ok for about 10 minutes and it would stop again.
I took out the blueNav sd and the gps is working ok.Is there anything I can do so that I can use the BlueNav sd again ?
Problem solved. I took out the BlueNav sd and pressed the menu and power buttons at the same time. Afterwards I tried with BlueNav sd and everything is working fine.
Posted on Nov 17, 2008
I'm trying to upload maps from mapsend bluenav software to my magellan meridian but it's telling me I need an unlock code. Does anyone know how to retrieve this?
Call Magellan and tell them the web page you were dircted to has been removed tell them your license number and they will unlock a sd card when you give them the sd serial number I went through this two years ago.the link you need has been removed from there server
Jul 08, 2010 | Magellan Meridian Color GPS Receiver
GPS Meridian - unlock SC card
Jul 18, 2010 | Magellan Meridian Marine GPS GPS Receiver
I cannot use fill colour for shapes, text boxes etc on either Word or Publisher -Office 2007 I click on fill colour but shape remains blank - a series of dots do appear around the shape.
Apply a different shape fill You can fill a selected shape (such as data markers, titles, data labels, or a legend) with a solid color, gradient, picture, or texture. You cannot use shape fill to format lines in a chart (such as gridlines, axes, trendlines, or error bars).
On a chart, click the chart element that you want to change, or do the following to select it from a list of chart elements:
  1. Click a chart. This displays the Chart Tools, adding the Design, Layout, and Format tabs.
  2. On the Format tab, in the Current Selection group, click the arrow next to the Chart Elements box, and then click the chart element that you want to use.
On the Format tab, in the Shape Styles group, click Shape Fill
  1. Do one of the following:
    • To use a different fill color, under Theme Colors or Standard Colors, click the color that you want to use. Tip Before you apply a different color, you can quickly preview how that color affects the chart. When you point to colors that you may want to use, the selected chart element will be displayed in that color on the chart.
    • To remove the color from the selected chart element, click No Fill.
    • To use a fill color that is not available under Theme Colors or Standard Colors, click More Fill Colors. In the Colors dialog box, specify the color that you want to use on the Standard or Custom tab, and then click OK. Custom fill colors that you create are added under Recent Colors so that you can use them again.
    • To fill the shape with a picture, click Picture. In the Insert Picture dialog box, click the picture that you want to use, and then click Insert.
    • To use a gradient effect for the selected fill color, click Gradient, and then under Variations, click the gradient style that you want to use. For additional gradient styles, click More Gradients, and then in the Fill category, click the gradient options that you want to use.
    • To use a texture fill, click Texture, and then click the texture that you want to use.
Tip If you don't like the change that you made, you can undo it immediately. On the Quick Access Toolbar, click Undo default.aspx?assetid=za101819851033, or press CTRL+Z.
Jun 01, 2010 | Microsoft Office Professional 2007 Full...
Magellan FX324
The Program for Sea Charts you are looking for is called, Bluenav xl3. Here is the information about these charts:
Note: You cannot combine MapSend BlueNav charts with any other MapSend applications on the same card and you will need a Secure Digital card reader/writer and you will need to be familiar with saving and renaming files on the reader.
OS Compatibility:
Is My MapSend® Program Compatible with Windows Vista?
(Click here) http://www.magellangps.com/support/faqdetail.asp?faqid=470&prodid=1142
Magellan MapSend BlueNav XL3 Charts for eXplorist (North America)Click here to purchase:
http://www.amazon.com/Magellan-MapSend-eXplorist-North-America/dp/B000HU4BXK
(Tip: On the Amazon website, you can click on the drop down menu for additional charts that are available.)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you!
Feb 07, 2010 | GPS
When i try to turn on the gps it asks for you to hit enter to continue but when i press enter it does not do anything and it then shuts down
Try reloading the firmware, its available on the Magellan website.
You may need some of the back door commands. There is wonderful trouble shooting information at www.mtgc.org/robertlipe/MeridianFAQ/ start reading about page 12. If you need to reload the master maps, they are on your MapSend Streets disk. With the laters firmware update I can use a 1GB SD card but I have not been able to get a 2 GB card to work.
Magellan no longer supports this device, so contacting them is a waste of time, they are rude, stupid, and won't tell you anything even if they know it.
Jan 15, 2009 | Magellan Meridian Color GPS Receiver
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Samsung SC-MM10S Blue Screen
CCD sensor seems faulty . Samsung should repair free of charge.
Aug 28, 2007 | Samsung SC-MM10S Camcorder
Open Questions:
Magellan Meridian Color GPS Receiver Logo
193 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
